Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
new race setup what you think it will run??
Old Mar 1, 2009 | 10:38 AM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i just put it togather after getting out run thursday night with out setup. no big deal but me and this guy have always raced.always been back and forth. my old setup was a 89 formula 5speed with stock vortec 350, holley 650dp, summit stage one intake, shortie headers into dual 2.5 in and posi 3.73. best of 8.6 @83 in 1/8. my new is 89 formula 5 speed with 350 with 9.75 cr, trick flow heads, perform rpm intake, xe274, rollar rockers, holley 650dp, shortie headers into duals 2.5 in and posi 3.73. what you think?
Old Mar 1, 2009 | 09:41 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Re: new race setup what you think it will run??
im runnin a 350 w/ vortec heads and xe274 and i 1/8'd 8.4 with a 2.260ft on junk street tires.... the cam has alot of midrange grunt and needs traction to be very effective
Old Mar 2, 2009 | 05:51 PM
intex1982's Avatar
what mph?
Old Mar 5, 2009 | 05:36 PM
MaNiAk86's Avatar
Car: 1983 trans am
my time slip doesnt say 1/8 mph for whatever reason sorry..
Old Mar 7, 2009 | 10:59 PM
intex1982's Avatar
it run a 12.985 @ 102.38 cutting out. with a 1.993 60ft bogging a little. it ran hard to the 1/8 mile 8.304 @86.69. after that starts cutting out. wish i knew why.
Old Mar 7, 2009 | 11:36 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
whats your ignition look like?? also, whats your fuel system?
Old Mar 8, 2009 | 11:11 AM
intex1982's Avatar
This motor been in two cars. Doing the same thing. First car had msd 6al and 8an fuel line with holley black pump set at 7 psi. Car now has summit hei dist and cap with stock tbi fuel pump set at 6 psi. The carb is the only thing both cars had on them 750 dp. in other car it made one full pass on street tire and run 105.99. really need some help
Old Mar 8, 2009 | 11:16 PM
intex1982's Avatar
anyone could carb cause this problem?
Old Mar 9, 2009 | 04:29 PM
5678TA's Avatar
Car: 1984 Trans Am
usually if it cuts out, its the ignition or a lean condition. HEI's are not the best thing to use for a performance motor. and 1 psi of fuel pressure makes a difference. bump up the pressure to 7psi and see what happens. if it makes no difference, ignition. thats the easiest way.
Old Mar 13, 2009 | 07:35 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Check your float level on that carb as well while your tinkering with everything.
Old Mar 13, 2009 | 09:35 PM
intex1982's Avatar
i checked it. and now going to try diff carb
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
pimp2303
Jul 27, 2017 02:03 PM
Street Lethal
Aug 13, 2015 08:28 PM
355tpipickup
Aug 13, 2015 07:35 AM
