What does everyone run / what's your setup?
Car: 1989 Iroc Z L98
I would love to see what everyone on here runs and the specs on your setup. I will start, all of my cars are DOT cars on street tires:
Current car: 1989 Iroc Z 5.7, 2.77 gears 2800 converter
Best: 14.6 @ 94.5
Previous car: 1982 Camaro 350HO crate with xe274 can
Best: 12.28@111.85
I will be doing heads can headers intake and carb this winter on my 89, I miss wearing a helmet
What is everyone else running?
Best: 14.6 @ 94.5
Best: 12.28@111.85
.What is everyone else running?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: What does everyone run / what's your setup?
My 89 that is getting torn apart to swap the engine into the 86 TA is:
RS, 3150 lbs wo driver
2001 6.0 LQ4, stock heads miller .030
Cam 242/248 .610/.615 lift 110 LSA
Hawks 1 3/4 swap headers
Trans, built T56, centerforce clutch
Rear, moser 12 bolt, 4.30 gears, 26x11.5x16 ET streets
Spohn tq arm, founders LCARBs and adjustable LCAs, bmr panhard.
Consistant 7.1 at 96 in the 1/8 on a1.55 60'
Been 7.0 at 97 on 1 pass and was at a quarter mile track, 11.18 at 122 and got kicked for no roll bar so it is the sole pass at a quarter mile.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
1990 IROC with stock L98 shortblock, 3400lbs with driver
Older AFR 190 heads, 60cc, 10.8:1
Ported Airgap with a 750 Mighty Demon
Custom 236/242 Roller, .580 lift on a 108LSA
Hooker Super Comps
700R4 with a 3600 Vig
4.10 Gears in the stock rear
Best so far (at my track) is an 11.89@115. It went 11.60@117 at Cecil. I am in the process of fixing a cracked piston, swapping to a TH350 with a 4800ATI. Goal - Getting kicked out of the track for no rollbar!
Hooker Super Comps
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Pancherj...you will love the ati converter!!
I made on own thread so ill just give ya the short version:
355 n/a with th350 trans and ati5300
Spohn and pa racing suspension
been 10.11@133 at cecil and 10.15@132 1.39 60' at capitol in 92 degree heat...on 255 drag radials
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
In good November air last season, 6.49 @ 104
406, Brodix Track 1 heads
AED 750,
12:1, Dougs headers, full exhaust into Dynatech splitflows
Stock sus. Moser 9", Spohn pro series torque arm.
3230 lbs with driver.
AED 750,
5.99@114
350 LT1, ported stock heads, hydro roller
single plane, 1200cfm throttlebody, 42# injectors
11:1, hooker headers with bullets
th400, fti 9" converter, ford 9" with 3.89 gear
185 shot with cheater plate, or 150 shot with edelbrock plate runs the same
275 radials
3050-3100lbs with driver
275 radials
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Best ET of 12.30@113, spinning bad one pass had a mph of 116.79. Stock 2002 LS1 with bolt-ons, 4.11 gears...until last week when I exploded the 9" at the track. Car is up and running with 4.30's now, 1/8th mile racing next Saturday.
Update: 1/8th ET of 7.62@90.73 Time to hit the quarter and get that 11.80 timeslip!
Car: 1990 IROC
I saw your other thread 86iroc2try...it got me excited to get back out there. I am pushing to make the final month of racing at Beaver Springs before winter sets in.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
It just sucks when its winter time....
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
10.72@ 126.24 1.49 60' 6.810 1/8 at 101mph
91 camaro 370 ls engine. 6.0 block. 030 over. ls3 heads 11:1 compression. hydra roller cam 850 proform carb. Th400 with brake 4500 converter. Estimated weight 3300/3400 lbs. Mosier 9"rear 4.11 with spool. 28x10.5 s et drags
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
357 motor, 10.9:1 C.R., Vic Jr., 650 Mighty Demon carb, Comp solid roller 236@ .050 .550 lift, Canfiled 195 heads. Cobra T-56 trans, Ford 9" 3.50 gears with a locker
Best run so far was a sad 13.3 @110.16 Car needs lots of suspension work and tires to hook, but mph suggests the motor is making decent power for what it is. Going to tear into the motor soon to see if I can get a little more power out of it.
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
So far I've been 10.97, @123. Plenty more still in it. Trying to get the rest of the car up to par with the drivetrain. Still sorting out suspension and proper gear to get the best out of it. Car is street driven all the time!
The motor is an 010 350ci block with Diamond billet main caps, Stock GM forged crank, knife wedged and lightened to 43 lb's. Eagle 6.0" rods. Ross Pistons 13.8:1 compression. Dart Pro1 heads, Schneider solid roller .680Lift. ProForm 950. Car runs on E-85 only. T400 with a brake, 5500 stall, Moser 9" w Detroit Locker.
Car: 1991 RS
Engine: 5.0
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
436 SBC,glide,stock suspension,single stage plate on 275's. 5.20's @ 135. New combo only has 18 passes on it and should run a bit better once it's ironed out.
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
You'll have to wait a little longer. I won't be at the october race since it's the same weekend as OC cruise. Converter is at PTC now getting adjusted and the car should pick up a bit next time out.
Car: 1985 Pontiac Trans-Am
Engine: AFR 235,Dart 400 Procharger F2. EFI
Transmission: Coan 400 + Gearvendors
Axle/Gears: racecraft 9"
85 ta, 400cid, afr 235, turbo 400, 3.25 gears, racecraft 9" madman TA, 295/55/15 DR, Procharger F2, 3700lbs w/me race weight. 1 3/4" headers, mufflex 4" Best times to date 8.74, 160mph, 1.30 60ft. Just finished 1420 mile drag week drive with 8.97 5 day average. Work in progress always. Thats it for this year though.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
forged 11.5:1 370" lsx, PRC stage 2.5 ls6 heads, carb, blah blah blah.
10.76 @ 126 in sea level conditions. haven't had those conditions in a while here. averages 11.0-10.9. 3400lbs. 93 octane and street driven.
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
1984 L69 with test pipe,original exhaust,under drive pulley,drag radials and 10" converter. 14.03 @ 94.4 MPH.
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
sbc 355 N/A, 906 vortec heads, .520/.540 lift and 236/242 duration hydraulic roller camshaft, q-jet with an adapter plate and manual steering. Suspension's just lakewood 90/10 front struts, 3 way adjustable shocks, sfc's, panhard bar, lca's and lcarb's. 275/50/15 drag radial. Car weighs 3200 with me in it.
Runs 11.9x @ 112 mph pretty consistently with a few slip ups of 12.0
Engine: 7.0L
the l69 cars were very surprising. didn't take too much for them to get going quickly. now beyond where he's at will take some serious thought though (not hard, just not easier either). i have a buddy that had an 85 lb9/t5 car that made some impressive runs with just a handful of bolt ons and free mods done.
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
88 base model, 383, 6 inch rods, 11:1, 492 Iron heads, 780 Holley, MSD ign, TH400, 3800 ATI converter, 9 inch 4.10 on a Yukon Spool, 31 spline Moser Axles, BMR adj torque arm, founders LCA, UMI LCA relocation kit, Spohn K-member, Spohn coilover kit, 3215 lbs car with me in it. 11.58 @ 117mph at MIR two weeks ago.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
82 camaro
434ci pump gas motor
turbo 400 trans
4.10 rear gear
3350lbs.
Best et in good air was 9.91 @ 136 on motor
turbo 400 trans
4.10 rear gear
3350lbs.
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
Car: 92 Z28
Engine: Boosted LSX
Its a Dart 400 block
https://www.thirdgen.org/forums/orga...drag-week.html
Engine: 305 spray 355 on 2 stages spray
Transmission: 700r4 **** kit th350 4000 stall
Axle/Gears: 4:10, 4:56
305 tpi 8.43 on bottle before upgrades runs 9.40s o.n motor 1/8 mile
Street Lethal
Aug 13, 2015 08:28 PM
