question on building a Turbo engine
Old Jan 26, 2003 | 04:46 PM
my88IrocZ's Avatar
How Do you build one, is there a turbo kit I can buy, what kindove compression, what type of headers do you get, And how much does it cost to build one? throw in anymore details I need to know. Right no I have a mostly stock 350 tpi and want to build a high HP engine. the rest of the drivetrain is done ( Moser 12bolt, art carr built 700R4, heavy duty steel drive shaft) Now I need HP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks for the help.
Dan.
Old Jan 26, 2003 | 05:13 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
It's your friend
Old Jan 27, 2003 | 12:03 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yep
Old Jan 27, 2003 | 12:43 PM
my88IrocZ's Avatar
B4Ctom1 is this a place to ask questions? or is it just to BS about things? everyone here says do a search do a search, then thay should call it a search board. I do not know much on turbos so I am asking questions. so unless you have an answer please don't reply with do a search. I just want some info on how to go about building a turbo engine.
Old Jan 28, 2003 | 10:58 AM
fly89gta's Avatar
Car: 2018 Camaro SS
#1 dude lose the attitude.
#2 This question/subject has been beaten worse than Rodney King...the reason why "search" was used because most of your general questions have probably already been answered in numerous threads, there is SO much info to give that one person would have to type a novel in order to answer a lot of the questions, questions in which have already been answered
No one was being a dick, just telling you to search first, then ask questions that haven't been already answered
Old Jan 28, 2003 | 11:14 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here Ill help read the following list of threads then ask me again list of searched turbo kit links
Old Jan 28, 2003 | 11:25 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Theres a sticky with some turbo stuff.
No, there isn't.
Really depends on the amount of power you want to make. You can run low boost and higher compression, or lower compression and more boost. Higher boost is going to make more power, but theres costs with the lower copmpression.
You're either going to need to find a set of turbo manifolds (ebay) or make your own.
Really depends. If you're good you could probably do it for under a grand. It gets expensive quick.
Like everybody said, do a search. Thats all been gone over before.
Old Jan 28, 2003 | 11:36 AM
Guido's Avatar
Car: 2000 Trans Am
I agree, read the sticky'd thread at the top of this forum and it should answer a lot of your questions. There is alot of time in the posts in that thread and they should do you well in answering your questions.
If they dont, then you can come back and ask more.
Old Jan 28, 2003 | 02:44 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here is a search link using turbo manifold https://www.thirdgen.org/techbb2/sea...der=descending
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
