Will it blow...
Old Aug 17, 2003 | 12:43 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Will it blow...
Hey guys ive had a N.O.S. Superpower shot set up sittin in my room for oh about 2 yrs and i havent gotten to install it becuz im worried it will blow a head gasket. the thing is that the motor has been rebuilt about 8 yrs ago by a pro. im curious too see if the motor can take just a 100 shot of nitrous and maybe 125 if i wanna push it. I have a stock replacement fuel pump (borg warner). i know i need atleast 6psi of fuel to be safe. and im runnin Accel shorty header plugs (8199 i think they are), i know ill need a colder plug also but the plugs i just put in 3 weeks are brand new.
and another thing is that the guy that sold me the kit used teflon tape on basiclly all the fittings, is that good or bad?
other then that i just need to get a different nitrous plate becuz i need a spread bore plate and i got a square bore. i know it gives me a good excuse to change to a edelbrock rpm air gap but i dont have the time right now.
but other then that stuff what sould i need to do to run it, i know i need fuel, good ignition (which is all good) and luck.
Old Aug 18, 2003 | 06:59 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
run the 75 shot then if all you have is the stock pump...
Old Aug 18, 2003 | 09:34 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
what kinda pump should i look into gettin if i wanna run a larger shot? my brother has a Holley he used in his 86 sport coupe and the thing didnt have a return port and he got vapor lock a bunch of times. im justwoundering who makes a pump (machanical) thathas a return port also.
Old Aug 18, 2003 | 11:56 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
NOS has people using a kit similar to the inline extra pump used in the procharger or vortech kits. If you have the instructions for these kits you can see what I mean. I also recommend switching out the rochester injectors they have a poor "pressure lock" threshold. The last thing you want to have happen when running a dry kit is for the injectors or even one of them to stick closed due to the higher pressures. I like the ford injector in these cases.
Old Aug 19, 2003 | 04:08 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
umm my car is carbed not FI. i bought the kit used and it didnt come with instructions. the plate was already plumbed and wired (the solionds), basiclly i just need to bolt the plate on hooker up the nitrous line, fuel line and wire up the switch (and ground it also) and then mess with the timming and carb.
i know i could use an inline pump too keep the fuel pressure up but wouldnt i need a regulator to keep the pressure coming out of the pump down or would the inline just make sure the machanical pump has 6 psi at all times?
Old Aug 21, 2003 | 10:24 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Use teflon tape on all NPT threads but NOT on AN threads.
Old Aug 22, 2003 | 03:44 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
should i just use the teflon paste on everything just to make sure, u know like a just in case kinda thing?
i hate this that i dont have any good base 1/4 mile runs on my car yet becuz i was goin to ask if even a 75hp shot will be noticable in my 1/4 mile time.
Old Aug 22, 2003 | 05:42 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
dont use teflon paste on everthing, just the NPT stuff not the AN - flaired fittings, read this https://www.thirdgen.org/techbb2/sho...t=teflon+paste
Old Aug 22, 2003 | 08:53 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i took a few shots of my plate setup, this is how i bought it about 2 yrs ago and i was told it had 125 or 100 shot jets in there. and looks like the guy was smart and used tape and not paste
Old Aug 22, 2003 | 08:54 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres the fuel side, im goin to redo the tape on that one fitting there but thats if i change to a new intake first but if i dont ill just put it on the new plate.
Old Aug 22, 2003 | 08:57 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
he's a shot of the whole plate. also if anyone knows anyone that has a spreadbore N.O.S. systems plate that they would like to sell or trade for a squarebore plate that will help me out becuz other wise i gotta give N.O.S. a call
Old Aug 27, 2003 | 11:20 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
so what do u think guys? would i be okay with a 100hp shot? if not ill just get jets for a 75 hp shot and see how it takes it. also is there anyway to find out what size jets i have in there? like does it have a number on the little jets or no?
Old Aug 27, 2003 | 10:53 PM
budda's Avatar
First things first! don't speak so lightly of the SQUARE bore! That is highly unusual and badly out of round. People be thinkin you been sittin on a 4x4. Man that be rough on the sphinkter! What you thinking??? Splinter was only a friend of Michaelangelo & Donetello!
Old Aug 28, 2003 | 02:34 PM
bigals87z28's Avatar
Car: Check The Sig
CHEATER!!!! YOUR GUNNA NEED ALL THE NAAAWS TO BEAT ME MAUAHAH! Tim, I didnt know you had a nitrous set up? When did you get this? wow your gunna start beating me soon! I better get thoes heads and cam in soon. Dont wana lose to a carbed 305!! hehehe see ya around man...
Old Aug 28, 2003 | 02:57 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Well i think after i get traction at the track i should be or will be beatin you al. but ive had the nitrous set up for about 2 yrs and mainly i couldnt use it becuz of the SQUAREBORE plate and i have a spreadbore intake (edelbrock performer) and well it just wont work if i where to bolt it on right now.
im just tryin to see what i can get out of my 305 before next yr when i should have most of my 383 built, im not decided on either a blower or a nitrous set up on it, im just goin to look for at least 500+hp.
Old Aug 31, 2003 | 02:14 AM
83 Crossfire TA's Avatar
Smart?
AN and for that matter, any kind of flared fitting is designed to seal with nothing on the threads. For that matter, the seal is made by the tapered seat at the end and not by the threads at all, and putting something on the threads to seal them will not help sealing at all either (if the seat doesn’t seal you’ll just get a leak at the swivel for the threaded sleeve anyway, even if you have the treads sealed).
Teflon tape probably shouldn’t be used at all on pipe thread fittings in an N2O system anywhere before the solenoid. You almost always get a little past the threads, and any that breaks off and travels to the solenoid could hold open the solenoid plunger and blow up your engine when you let off the gas. If I received N2O parts like that I’d take them all apart, remove all the tape clean everything well so there aren’t any traces of the tape left and then blow out the insides of all the lines, fittings… in both directions with some compressed air. If you have an NPT fitting in the system, I’d use a little bit of a good pipe dope on the threads, nothing with any solids in it (some ‘teflon pipe thread sealants’ have little strings of Teflon in them that could cause the same issue so they’d be pretty low on my list of stuff to use).
90% chance you won’t have any problems with the tape, but why take the risk?
Old Aug 31, 2003 | 03:26 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah, the guy i bought it from said he had it on his old iroc and used it at the track alot, he took it off and it sat for a yr before he sold it to me and well lol its still sitting. so basiclly i should remove any teflon tape after the seloniod?
Old Aug 31, 2003 | 05:07 PM
at the very lest, all of it before the solinoid, I'd get rid of all of it.
Demo77
Mar 26, 2011 06:23 PM
V8Astro Captain
Apr 6, 2003 01:39 AM
CD MaroMan 91
Car Audio
24
Nov 19, 2001 11:29 AM
92fire-audio
Oct 17, 2001 11:47 AM
