boost and stealth ram?
Old Sep 16, 2003 | 03:13 PM
jeffsbluez's Avatar
Car: 91 z28
Has anyone with a blown/turbo car had any problem with the top of the stealth ram lifting off? This may seem like a dumb question but, if a blower/turbo can lift a head with 10-17 bolts holding it down why the plenum? It only has four little bolts holding it on. Your thoughts are appreciated.-Jeff
Old Sep 16, 2003 | 03:58 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
big difference between 8-16 psi boost and 25000 to 50000 psi of combustion.
Old Sep 16, 2003 | 04:29 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
The plenum bolts are pretty long. Id think they would do the job just fine. Either way I'm about to do a blower/AFR/stealth ram build so i'll let you know soon enough.
Old Sep 16, 2003 | 05:10 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
This guy is pushing some boost.Id say worrie about the rubber boots poping 1st befor pulling the plenum bolts out.
http://community.webshots.com/user/bbunting100
Old Sep 16, 2003 | 05:59 PM
jeffsbluez's Avatar
Car: 91 z28
Thank you for your input people. B4Ctom1, you make a very good point.
Old Sep 16, 2003 | 07:12 PM
biggtime's Avatar
I use one with 14lbs of boost, with no problems. Although throw
the flimsy gaskets out that come with it and make your own. They
did push out the first time i got into it.
Old Sep 17, 2003 | 01:23 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
thats interesting to know!
Old Sep 17, 2003 | 09:31 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
I have blown the head gaskets twice, the intake tubes, but never the top of the intake.
Old Sep 18, 2003 | 12:08 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I figured headgaskets or bellows would be the 1st to go.
Have you considered a composit gaket or oring block/head for wirelocks?
Old Sep 18, 2003 | 07:54 AM
bbunting's Avatar
Car: 1990 IROC Z
Yes- I have the wirelocs in now-it also helps to have a safe A/F ratio-something about running 20+ lbs. and 17:1 A/F.......boom!
So I "detuned" it now to only 11.95 PSI and 11.5 A/F.
Old Sep 18, 2003 | 09:01 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Dammm,
Any new Pic's or videos at all..
Old Sep 18, 2003 | 09:02 AM
bbunting's Avatar
Car: 1990 IROC Z
Just the videos in my sig...the newest is the SORC clip
Linson
Oct 24, 2025 02:00 PM
$750 L98
Feb 1, 2025 02:25 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
