Throttle body relocation
Old Jul 8, 2004 | 11:49 AM
biggtime's Avatar
I am putting a D-1 on my car now. with a intercooler in a ice box on front pass side floor.
My question is has anyone thought about relocating the throttle body on a HSR to the side like a mustang? If I plate the front on the plenum i will have the room to run the piping by. I would have to fab up a spacer to clear the fuel rails. With the throttle body on the pass side I would only need 1 elbow to go thru the firewall.
I was also thinking it would help with the two rear cyl. that like to run a little leaner.
Old Jul 9, 2004 | 12:58 AM
83 Crossfire TA's Avatar
As long as you don't dump right at one of the runners you'l be fine. OTOH, I'd probaby seriously consider building a custom plenum for the application.
Old Jul 9, 2004 | 07:23 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Why not use the Accel Pro-Ram, or just weld on some injector bungs to a Victor Junior? With a 4 barrel TB or an elbow, it can be pointed anywhere, and not have flow distribution issues.
Old Jul 9, 2004 | 07:58 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Id also say VIC JR. converted. sell the HSR.
your post reminded me of the FIRST setups.
Old Jul 9, 2004 | 08:06 AM
biggtime's Avatar
Basicly I am building a new plenum. I was just wondering if anyone had tried or had any ideas on a side feed intake system.
My thoughts were that if the plenum size was big enough, which it will be when I am done, and it is pressureised i should not have any flow issues.
I do not want to do a single plane manifold at this time as i am still testing the other one I built. I made one for my turbocharged Typhoon and tried to get my plenum volume from using a large 4" ID 90. Everything that I have read tells me plenum volume on boosted applications must match or be bigger than the CID of the engine.
Old Jul 9, 2004 | 08:08 AM
biggtime's Avatar
Thanks for the pic's BUT that one would really scare me for being boosted! I
Old Jul 11, 2004 | 11:59 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you mean like a chevy version of this?
Old Jul 11, 2004 | 02:08 PM
biggtime's Avatar
I have one of those already I built,(below) I was wondering if anyone has did it with the long runners and large plenum of the HSR
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
