Sound clip - m90 on 305 TPI
Old 05-16-2005, 11:12 PM
87Formula4bbl's Avatar
Car: '87 Formula
The other thread was getting long so I started a new. This is a clip I recorded just this past weekend of my brother's car with the m90. I wish I still had my camcorder but this will have to do for now.
Sound Clip
Link to old post:
https://www.thirdgen.org/techbb2/sho...hreadid=277250
Old 05-17-2005, 06:54 PM
Mike-91 Formula 350's Avatar
So i'm guessing you guys have road tested it by now.How does it perform?
Old 05-17-2005, 09:23 PM
Car: '87 Formula
Hard to tell just by riding in it but I'll go out on a limb here and say its a little faster than it was before
Ya, it pulls pretty good. It was nice for me to finally get a ride in it after putting hours into the thing.
Our next goals:
1) Get it quieted down. I'm pretty sure the noise is coming from air screaming through the intake tube. If you think about it, on the Supercoupes and GP's and such, the TB is before the SC, therefore its not sucking all that air at idle/cruise that this one does. I'd like to route the bypass valve outlet to the intake and see what that does.
2) And get more boost, duh. There's a few ways to skin this cat, but I think it can be done without going to extremes (we're talking 6-7psi, nothing huge).
Old 05-17-2005, 11:15 PM
83 Crossfire TA's Avatar
Heh… I warned you that it was going to be loud… I wish I had a sound clip of my brother’s car, he’s running a lot more rpm then you are and his whine is much worse.
On the factory setups the whine is deadened by the actual TB blocking it and by the air filter/air box design and location.
Old 05-21-2005, 10:43 AM
It is loud but sounds bad *** on the tape.I'm sure a person would get tired of it after awhile though.What kind of boost are you seeing under load?
Old 05-21-2005, 10:46 AM
Car: '87 Formula
He gets about 5psi under WOT.
Old 05-21-2005, 11:34 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Ah..... sounds like an Eaton to me...
Yes it does get annoying after awhile... especially with two.
Getting much belt dust yet? Bob
Old 05-23-2005, 04:13 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
My GTP was quiet with the factory air box they designed that to make it fairly quiet. Now that i have a fender well intake its pretty loud. I have people comment on how loud it is all the time. The M90's are loud when you have no baffling to quiet it down.
Old 05-23-2005, 03:01 PM
Car: '87 Formula
Eh...there's a little bit, I'm guessing it's not completely lined up, but it hasn't thrown a belt, broke one, squeeled or done anything else unnormal.
gta90
09-15-2015 04:00 PM
drewdock87
South Central
08-18-2015 09:02 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Sound clip - m90 on 305 TPI
