MAF and Turbos
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
MAF and Turbos
I am new to MAF tuning and heres a question.
Will a MAF engine detect and compensate for boost levels in the range of 0-8 psi coming from a Turbo (RMT if thats relevant)?
Re: MAF and Turbos
you need to change computers or run an FMU.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If you don't max. out the MAF it would work fine. Most of the time power adders max out the MAF so an aftermarket or larger GM would be necessary along with a signal translator.
There is no boost GM MAF ECM that I know of. I have only seen the MAP ECMs with boost code. Maybe GM/Holden has a boosted MAF application.
Car: 1991 Firebird
Re: Re: MAF and Turbos
Originally posted by nightrider87
nope
nope
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
yes and know, more of them that i have seen in summit only rase fpr on a 1:1 ratio, to run a 12.5.1 afr with stock size injectors its sead you need a fmu with 12:1
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
IIRC, even a stock 350TPI is near or past the flow limit of the MAFS. Even if the MAFS could sense the extra airflow, there is no way that the stock injectors could flow enough fuel to feed the extra airflow, even if the injectors were hung open at 100%DC (unless you increased the fuel pressure, such as with an FMU).
You can blow through a stock TPI MAFS with a turbo or supercharger and have it work well. My TT IROC uses a Vortech SFMU, Ford SVO 24# injectors, and a stock pump with a 50/70 T-REX inline booster pump. I use a stock ECM and the charge air goes through the stock MAFS after it passes through the intercoolers. Its been reliable and very driveable for almost four years now. It gets 20mpg on the highway and runs mid 12's in the quarter at 6psi of boost (its more driver than racer).
Car: 86 iroc
Originally posted by 89JYturbo
Ditto.
Ditto.
Car: 1991 Firebird
Just thought of something. MAF senses airflow by how much current it takes to keep the wires heated while the airflow cools. Would the IAT tables be setup to compensate for the abnormal heated air?
