got some dyno time today...new numbers
Old Jan 25, 2006 | 11:25 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
hey guys got some dyno time today...whenever my buddy is there and the boss is away i can sit on that thing for the whole day if no other customer comes in lol! I hooked up the snow meth/water kit i had for the longest while, raise the boost to 18psi and set the BTM to pull 1* per lb of boost and played around with the afr until the WB showed 11:2 @WOT. I'm still in shock at the 682.3rwhp @ 6400rpm and 707ft lbs @ 5045rpm. The yokohamas stayed on the rollers better than i expected though. I drive the car a lot on the street though so i probably won't leave it at this setting for too long in concerns of reliability but will definitely run it at the track with this tune a few times though. Them cobras, ls1's and vettes have yet to experience their worse nightmare!
Old Jan 25, 2006 | 11:29 AM
slapi01's Avatar
Car: trans am
Engine: sbc350, afr 180cc head, comp full roller, xtrem 276,comp 1.6 roller rockers,weiand142
Transmission: tremec tko
Axle/Gears: 8.5 3.73 gear, moser 30 spline axles,eaton posi
those are some killer numbers you put down and really look foward to hearing about the @$$ beatings you put on thoses ls1's.
Old Jan 26, 2006 | 02:18 AM
89ta383sc's Avatar
Car: 89 ws6 trans am
Engine: 383 supercharged
Transmission: t-56
Axle/Gears: 9 inch 3.90's spooled
What is done to yuour fuel setup? what kind of duration is on your cam?
Old Jan 26, 2006 | 05:12 AM
Dan W's Avatar
You work at the carberator shop?
Old Jan 26, 2006 | 10:24 AM
89ta, my fuel system is made up of a custom stainless steel "stealth" tank from Rick's Hot Rod Shop with the aeromotive A-1000 pump and filters inside it and their boost referenced return style fpr and my cam dur. @ .050 is 226/238 on a 116 lsa.
Old Jan 26, 2006 | 01:44 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Is that an FMU ? WOW ! Sick digits man .
Old Jan 26, 2006 | 06:12 PM
I don't use an FMU...if its the little cheesy ones that vortech and ATI sells with their kits you're talking about.
Old Jan 26, 2006 | 10:12 PM
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
your car
What belt setup are you using? Is 6, 10 rib or a cog setup?
Later,
Robbie
1fas92
Old Jan 29, 2006 | 12:20 PM
1fas92, im using the 12 rib set up....I had to modify my radiator location as in moving it forward a little so the pulley would clear the radiator/hose but its the next best thing to expensive cog driven setups.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
