I know some of you are running the Accel DFI setup....I need help.
Old Dec 21, 2000 | 10:47 PM
crazeinc's Avatar
Hey guys. I think I'm going to ditch my carb actually. I never thought I'd see the day, but I do believe it might actually happen.
The Accel DFI kit says it's for up to 510hp. That's fine and dandy for the 350 I have now, but what about the 383 I'd like to put it on that's either going to be supercharged or nitroused? Will it not work right or what?
I saw that holley has a nice EFI setup that has plenty of room for gobs of power. Commander 950, I believe.
The '82Z
Hugger Orange
383 4 bolt main
3000 lbs
Bad cornering
NOS Sportsman Fogged
10 bolt braker
Coming to a street near you in the spring...
The car's website
Old Dec 22, 2000 | 12:58 PM
GMI FAST's Avatar
The Pro-Ram system you are referring to is only limited by the injectors they include with the kit. Order the system with the injectors you like, and the intake will support hundreds more horsepower...
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
www.mfba.org
Old Dec 22, 2000 | 01:27 PM
maniacc's Avatar
GMI,
what would you suggest for a replacement ecm for a tuned port engine, I'm trying to find something that is as close to plug and play as possible...I really dont want to have to keep getting a chip burned everytime a make a change to my engine....does accel make anything that will plug into the original engine harness??? My car is a stock(MAF) 5.7 w/ATI 10#'s of intercooled boost,
any help would be appreciated,
later,
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and soon to be supercharged
http://maniac.megamania.com
Old Dec 22, 2000 | 03:28 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Maniacc, try talking to EFI Systems. They are the guys that make the PMS (Programable Managment System) controler. It plugs in between the stock ecm and the harness. It retains all factory accesories & emissions equipement but gives you complete control. It comes with it's own palm size controller or you can use a laptop. It has data logging too.
Also FastTrack Performance makes "piggybag harnesses that allow you to retain your stock ecm and use the Accel or Speedpro ECM to handle fuel & spark. They have splice, in or plug in harnesses. the PMS is cheaper. With the Fast Track setup you have to buy the adapter and the ecm setup + laptop.
Tracy /AKA IROCKZ4me
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited December 22, 2000).]
Old Dec 22, 2000 | 11:12 PM
robzr's Avatar
What are the general vibes about the new Accel DFI Pro Ram system? It seems like a great deal, 510 hp MPFI setup for $1800. What advantages does the Superram offer for another $1200?
Application - 388, AFR 195s, 224/230@.05 roller hydraulic, ~450 hp @ 5500 in a 76 Vette.
Rob
Old Dec 22, 2000 | 11:54 PM
True Power's Avatar
There's a problem with that Programmable Management System...it's not offered for Camaros! Go to their website, then to priving, then to General Motors, and it will state "no longer available." Which sucks, it looked like a great system to me. Does anyone know if they can custom-build a GM version? I do NOT see why they don't do f-bodies or y-bodies
Old Dec 23, 2000 | 03:22 AM
IROCKZ4me's Avatar
They used to make one that worked on all camaro & corvette from '86 to '90 TPI and TBI. I called & talked to one of the guys from EFI Systems about the PMS for GMs. He said they ran out of parts to make them for the GM application and just didn't order any more parts to make more because they weren't getting a lot of orders for them . I know they would have sold more of them if more people knew about them. They are a great system with awesome capabilities. They retain the stock ECM to run the ancillary devices. They are super easy to install, You just unplug the stock ecm and plug in the PMS harness between the stock ECM and its stock plug. They give you complete control of spark & fuel. They have boost auxilary enrichment, Nitrous control, nitrous fuel enrichment, boost & nitrous timing retard, rev limit control, torque converter control, cold start tuning & tons of other stuff including data logging. It is a killer setup. You don't even need a computer to tune it but you can use one if you want to. I wish I had known in advance they were going to stop making them for GMs I would have bought one or two to have for future projects.
Maybe if enough people asked them to, they would order more parts & make some more for the GM app. I would be willing to order one or two to participate in a group purchase if any one was interested & if EFI Systems would do it .
If anyone has one they would like to sell (new or used) let me know.
  • 355 cid
  • AFR heads
  • fully balanced
  • SLP cat-back
My IROC-Z
Old Dec 23, 2000 | 09:29 AM
GMI FAST's Avatar
robzr: I am currently using the Pro-Ram on my turbocharged 406, which will be installed this winter. It is best suited for either large-cube or high rpm applications. Or both. Super-Ram is for more low-end torque, but is also a bigger pain in the butt to install and service...
Employed at:
Hahn Racecraft
www.mfba.org
Old Dec 24, 2000 | 12:26 AM
True Power's Avatar
IROCKZ, I emailed them, asking them if they would maybe put together a custom one for me. Haven't gotten a response yet, but that's understandable, being near the holidays and everything. I'd definately be interested in a purchase like that. I BET that with the right pursuasion, we can get a couple made for F-body fellas such as ourselves. I'll let you know what their response is. Email me if you wanna talk more about it... wolf6t9@swbell.net
Old Dec 24, 2000 | 01:17 PM
IROCKZ4me's Avatar
They already have the engineering done. They were producing them. They say they just didn't reorder parts. These are "killer" systems. One part number works with 86-90 TBI or TPI. That's a lot of applications covered. If they got enough order requests they may just consider ordering the parts & building some. I hope so, like I said they are one of the best I've seen.
  • 355 cid
  • AFR heads
  • fully balanced
  • SLP cat-back
My IROC-Z
Old Dec 24, 2000 | 07:10 PM
crazeinc's Avatar
GMI, does that Pro-Ram come with the Accel DFI kit or is it a seperate piece?
And I'm just making sure. Eventhough the DFI kit says it's good up to 510 horses, I can put in bigger injectors that will allow it to handle higher horse situations?
Or is that just for the Holley MPFI setup?
Old Dec 24, 2000 | 09:21 PM
GMI FAST's Avatar
The Pro-Ram is available as a complete setup with DFI, or you can purchase each item individually. To help handle my 800 hp goal, I am having my Pro-Ram port-matched to my heads as well as ExtrudeHoned. I am also running 72# injectors. It is a very nice setup...
Employed at:
Hahn Racecraft
www.mfba.org
Old Dec 25, 2000 | 10:48 PM
crazeinc's Avatar
Where's a good place to pick up one of those kits?
I would also like a few shots of the setup...
[This message has been edited by crazeinc (edited December 25, 2000).]
Old Dec 26, 2000 | 08:05 AM
bhoward's Avatar
Hey TruePower, I would also be interested in getting one of these (PMS systems)if they would make them.Let me know what you find out from them.I would bet we could get at least 10 people interested in these units.You know I had never heard of these until I read this thread but from what I read about the system they sound realy sweet.Keep me posted via this thread or my email bhoward@cappsvanrental.com.
Old Dec 26, 2000 | 12:34 PM
GMI FAST's Avatar
crazeinc: I sell Accel products. Email me at sales@turbosystem.com for your pricing. Check the Mr.Gasket/Accel websites for photos...
Employed at:
Hahn Racecraft
www.mfba.org
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
marcusaw
Aug 10, 2015 08:13 AM
