Hey Procharger guys look who signed my guestbook!
Old Jun 22, 2001 | 05:40 PM
PROCHARGED89Z's Avatar
http://apps3.vantagenet.com/zgbs/lis...sp?id=23274243
Dorian from ATI.He's a great guy.Pretty cool.
On another note I havent heard from Maniac latly.Anyone heard from him at all.Just heard he has the blower in and he loves its.
Hows the alcohol injection system comming Willie,Im makin a kit for mine to run etonol or alchy with a trunk mounted aluminum tank,can get it made real cheap.My cousin makes boat tanks,real good aluminum welder.Will cost me about $50 for the tank most likly 3 gallons,comes with a sending unit and outlets.When I get picks let me know if you or anyone else here is interested
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Jun 22, 2001 | 07:33 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Darren,
Larry called me a couple of days ago. He's been busy with work lately.
I finally installed my water injection system and tried it out a couple of weeks ago. You would not believe how quickly it lowers my air temp. I had to eliminate the long rubber hose in front of the throttle body, replaced it with a piece of polished aluminum fitted with the water injection nozzle (on the bottom so it's completely out of sight). See:
<IMG SRC ="http://albums.photopoint.com/j/View?u=1427158&a=13353890&p=50780225&Sequence=0&res=high">
Suffice it to say, I can't wait to hit the track on June 29th (rain permitting)!
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (5-psig): 12.26 @ 113.55 mph
ATI D1SC (10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited June 22, 2001).]
Old Jun 23, 2001 | 10:26 AM
a73camaro's Avatar
SLICK H2O injection setup you got there.
I assume you're injecting water through the top three injectors behind the throttle body.
But I am curious about the use of water thru a stock appearing injector. Will rust be a problem??
Thanks, and again COOL setup.
Old Jun 23, 2001 | 12:45 PM
Willie's Avatar
The three injectors are part of my Superfueler system. It is boost activated and the amount of fuel injected is electronically controlled. The water injection nozzle is not seen in this pic. It is mounted on the polished oval piece in front of the throttle body. This piece is not part of the ATI kit. The kit comes with a long rubber hose instead.
My water injection pump is located next to the charcoal cannister.
Willie
Old Jun 23, 2001 | 04:41 PM
Willie,I have a chance now to buya system as well,just would like your imput.I am either going to make mine or buy this one.The SMC kit that sells well over at the turbobuick.com site.I was wondering how fast your water injection lasts,the container supplied with the SMC kit is only half a gallon.Your thouhgts here is the link to the kit
http://www.geocities.com/rad87gn/tech/SteveCkit.html
How long does the water injection last?My friends with the Paxton injection I remeber didnt last very long,Im not quite sure.Thanks Willie
Old Jun 23, 2001 | 09:17 PM
maniacc's Avatar
Darren,
Yes, I'm still alive and kickin', My car is running great, and i haven't been able to wipe the **** eatin' grin of my face since i raced a new camaro SS and whooped his a$$!!!
That's cool that Dorian checked out your website, he's one alright dude!!!
have fun
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
Old Jun 23, 2001 | 11:30 PM
Willie's Avatar
Darren,
$349 for the SMC kit seems like a good price. But I believe the braided steel line is overkill. I use 3/8" rubber hose. You also get a lot of bells and whistles that you will never use. And where are you going to mount that huge tank? It seems the braided line they supply isn't that long....
I use a 14# stainless steel nozzle (same as SMC) screwed into a brass bung, both pieces purchased from Carroll. I fabricated the aluminum "oval" in front of my throttle body and JB welded the nozzle to it. I use a 100-psig Carroll pump and a 1/2 gallon reservoir. The reservoir lasts for a minimum of eight passes at the track. Heck, you probably refill the windshield washer reservoir more often....
Willie
Old Jun 24, 2001 | 12:25 AM
Bobalos's Avatar
I suppose there ought to be another post, on this topic but, while we are talking about it. what does the injector nozzle look like? does anyone have a good picture of one? I can get a N2O fogger nozzle & was thinking about playing around with making one.
If you are getting 8 runs on 1/2 Gal, that is about .325 Gal/min. Does that sound about right?
have you ever looked @ the output of the nozzle when it is spraying? I wonder if it looks like a fine mist or if it is just squirting out.
boy 100 PSI pump, I am thinin that could not have been cheap. where did you get it (with the kit)? how much was it?
thanks amigo
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
&lt;&gt;&lt;
Old Jun 24, 2001 | 12:53 AM
Sorry Willie I didnt tell you the kit is now on a Gp for $300.I talked with Steve on the phone,a real nice guy answered alot of my questions.Said he can upgrade to a bigger tank that will hold one gallon for about $40.I dont have winshield washer tank now and Steve told me its not a good idea to run denatured with a winshield washer bottle.Seems he has seen leaks develop after time.And the braided hose is for safty he told me says denatured is very flamable.I thingk the low light indicater is a good addition and I dont have to change nozzles since I can adjust the pump flow from the drivers seat,and dont have to bother with hobb switches either.It seems like a very good kit,and the pump is mounted in the tank to.Well for $300,or the upgraded size tank for $340 seems like a good deal.He told me with the 1/2 gallon on his car he gets about 6 full passes on it,and some street driving,but he is running 22lbs of boost on pump gas,with little or no knock.
[This message has been edited by PROCHARGED89Z (edited June 23, 2001).]
Old Jun 24, 2001 | 09:52 AM
Maniacc,Im glad to see you are happy with the kit.Did you get to catch the look on that SS owners face .Are you bothered by the whine at all Larry?Good luck and I hope everything works out.
Old Jun 24, 2001 | 04:34 PM
maniacc's Avatar
Darren,
I did get a look at him afterwards and he had this dumbfound look too him.
And NO-WAY am i bothered by the whine, the only time you really hear it, is when your putting around, which is just about never!
Its a blast going too car shows, it definately grabs some attention when your pulling in or leaving
I will get some pics next week of everything all complete and cleaned up
Still grinning from ear to ear
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Infested
May 22, 2018 11:56 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
matthew911
Aug 12, 2015 09:38 AM
