please don't hurt me.
Old Sep 12, 2001 | 01:36 PM
slowV8berlinetta's Avatar
would it be worth anything to use a smog pump as a centrifigal supercharger?? soe one once told me that it would be worth something like 40hp. i think it's ridiculous hearsay, but what do you guys think???
'84 Berlinetta, LG4, 700R-4, starwars interior, falling headliner, T/A t-handle shifter, trans cooler, more to come in time and $$ www.hipergp@aol.com
Old Sep 12, 2001 | 02:53 PM
mefreema's Avatar
I saw an artical on the internet that talked about that. The smog pump was used as a supercharger for a briggs and straton go-cart engine. The author of the artical said he once used it for a V8 application. He had like 6 of them run in series. The first one's outlet would connect to the next one's inlet and so on throught all 6. He said they were very efficent and it drove all 6 pumps well enough to create a decent about of boost for even a V8. The 1st pump attach to the drive belt was rigged with a AC clutch so he could turn the rig on and off at will. He had a picture of the go-cart setup but not the V8 setup. I dont know if it would really work or not but I found it kinda interesting. If anyone know how to make that work I would be interested in knowing too. Might be more feasible on a 4 banger though.
Old Sep 12, 2001 | 03:17 PM
Guido's Avatar
Car: 2000 Trans Am
It IS ridiculous hearsay.
-86 IROC
11.31 @ 120.2 mph
-=ICON Motorsports=-
Old Sep 13, 2001 | 08:55 AM
mefreema's Avatar
I found the internet artical about using a smog pump as a supercharger. Here it is
http://www.richmondlabs.com/Automotive/DCSP.html
Be sure to follow the link off the site to get more detail about this guys setup or just use this link below.
http://www.richmondlabs.com/Automoti...argerPost.html
I am in no way saying this will work or you should try it. But you asked so here is the info I know about it. So don't look at me like a dumb A$$ hahaha
Maybe I will strap one of those bastards to my 1997 KX 500 dirtbike!!! I am going to Silver Lake Sand Dunes this weekend and I would be sure to wins some races with that baby!!!
Old Sep 14, 2001 | 01:45 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I wouldn't try to use one to super (sub?) charge a V8 but you could potentialy make a horsepower gain (particularly on a boosted application) using one to draw a vacuum on the crankcase. You would have to use one with an intake duct or pipe (that you can plumb to a valve cover or lifter valley) instead of the type with the intake behind the pulley.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Sep 14, 2001 | 01:56 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
Actually, have you ever thought about just attaching a rubber band to a little propeller near your intake? Might have to wind it up every now and then, but it would probably look just as pitiful :P
Old Sep 14, 2001 | 05:19 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I am in with the idea that it would probably not work. I had a Turbo Coupe and the little IHI, about the size of a T3, had a hard time keeping the 4 banger fed.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Old Sep 15, 2001 | 11:32 AM
86 IROC's Avatar
In the circle track race shop I worked at, the used them crankcase evac pumps. But, there are very few of us on this board that turn their motors high enough to need one. Maybe on a SC'd application. I don't know, nor am I going to speculate on that. I'll leave that to the people that are running blowers on their cars.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
CORV3TT3
Aug 23, 2015 11:26 AM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 13, 2015 07:36 AM
