daves12secV6
Old Oct 9, 2006 | 07:59 PM
E-Z Rollin's Avatar
daves12secV6
I've read many of your post and I'm interested in the specifics of you engine. Is it a basic stock 3.1 with the iron heads ? I, researching for a 3.4 turbo project. Your help will be appreciated !
Old Oct 10, 2006 | 01:21 PM
daves12secV6's Avatar
aside from the bottom end,the top end was nothig more then a ported set of stock iron heads with a stock manifold that was port/gasket matched.
the bottom end was also stock crank/rods.but i had installed arp rod bolts,and had gone with some forged pistions with the stock cr of 8.9-1.if u dont plan on running mo0re then 8-10 psi there is no real need to goto forged pistions,unless u plan on running nitrous,or u just want the added saftey of forged pistions
Old Oct 10, 2006 | 03:34 PM
E-Z Rollin's Avatar
What was your best 1/4 mile e.t. with that engine and at what boost ?
Old Oct 10, 2006 | 03:42 PM
12.6@112 16 psi, in a somewhat gutted car,i removed my system and everything i could out of the car
Old Oct 10, 2006 | 06:12 PM
E-Z Rollin's Avatar
I don't have any hands on expirence with turbos but have built 5 na engines with good results. I have good basic knowledge of turbos and trying to learn more. It appears that the two biggest problems are fuel and ignition management. Since I have a 3.4 wouldn't the 3.4 sfi intake be my choice, using megasquirt.
Old Oct 11, 2006 | 08:26 AM
i myself just got megasquirt,and the plan was to make the swap over the winter.
now the 3.4 engines had dis ignition system,so im not sure how to make that work with megasquirt.if u use the 3.4 sfi intake u have to run dis,but if u swap over to the 2.8/3.1 intake u can run a distributor.for the most part just about all the v6 guys that do do the 3.4 swap swap back on the 2.8/3.1 manifold so they dont have to worry about the ecm/harness change.
either way will work,u just have to make sure u can controll the dis with megasquirt
Old Oct 11, 2006 | 04:52 PM
E-Z Rollin's Avatar
Does the sfi intake block the dist. access ? Are the mpfi manifolds and ecm's equal or are some better than others,I have a u-pick'um yard here that's reasonable.Also I could consider the 3400 alum. head /intake swap since it seems to offer much more potential .
Old Oct 11, 2006 | 06:33 PM
if u swqp to the aluminum fwd heads u also have to swap in wd pistions.cause the chamber cc of the aluminum heads is half of the rwd iron heads.if u swap heads without the pistions u will have around a 14.6-1 cr.also swaping to the fwd heads/manifold requires u to swap to dis iginition.
the 3.4 manifold does block the dizzy.if ur gonna swap to a 3.4 and keep the iron heads just use a 2.8/3.1 manifold,unless u are going to run the dis tyhen use the 3.4 manifold,unless u want it to look like a stock 3.1 engine
Old Oct 12, 2006 | 03:16 PM
E-Z Rollin's Avatar
I think that I will just stick with a modified stock block and heads just to see what results I can get. I will have more ? in the future.
Picolini
Jun 2, 2008 11:40 PM
92camarorv6
Apr 29, 2008 10:02 AM
hachiroku_rs
Nov 17, 2007 12:06 AM
ttypecamaro
43
Jan 24, 2007 12:07 AM
koen92firebird
Nov 24, 2006 07:39 AM
