pics needed :v8 intercooled twin turbo setups
Old Oct 17, 2006 | 12:27 AM
daves12secV6's Avatar
hey guys i was wondering if u guys could post up some pics of ur twin turbo intercooled setups.
im gonna be doing a 4.3 vortec swap in my 89 rs starting this weekend.and im either gonna run twin t04e turbos or do a single t70.so id like to get some ideas on how to run all the cold side pipes if i do go with the twin setupsince the 4.3 is gonna be pretty much the same as all u sb guys.which id rather do then a single turbo setup.
thnx guys
Old Oct 17, 2006 | 12:55 AM
trbo355's Avatar
I dont have any pix of my intercooler setup but it fits my core dimensions like it was made for it! It came off of a 99 freightliner with a navistar engine i think. Got it at the local wrecking yard for 250 bucks. I had to relocate the inlet/outlets to point straight down and notch the core support out accomodate them. Your sig. says you are going to use a 2004r. I love those trannys' but beware that they bust the forward input drum drive stub off around 550 whp. I built one for a Buick GN that runs 10.50's and it just broke the planetaries inside too. The planetaries doesnt happen too often but the drive stub IS the weak link. There are upgrades but i dont know much about them yet.
Old Oct 17, 2006 | 08:44 AM
turbobike's Avatar
Car: 87 WS6 Firebird
I went with twin 57mm, liquid to air intercooler. Not enough room to run an air to air with a Firebird front end, effectively.
Old Oct 17, 2006 | 09:26 AM
superirocz's Avatar
my setup
Old Oct 17, 2006 | 09:29 AM
superirocz's Avatar
maybe
Attached Thumbnails pics needed :v8 intercooled twin turbo setups-tt.jpg
Old Oct 17, 2006 | 08:33 PM
turbobike
thats a really nice clean setup
thnx for the pics ,any chance u have better pics of the way u ran the turbo discharge pipes?
Old Oct 17, 2006 | 09:30 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
https://jshare.johnshopkins.edu/asch...rcoolerpic.JPG
https://jshare.johnshopkins.edu/asch...ers_bottom.JPG
Just click cancel if it asks for a password.
thunderbird turbocoupe ICs. $4.24 and $20 on ebay. IAT:112 @14psi and high 80's outside in August.
Old Oct 17, 2006 | 10:21 PM
ttype ur pipes come out over the upper radiator supoprt right?
Old Oct 17, 2006 | 10:28 PM
yeah...
https://jshare.johnshopkins.edu/asch...t/000_0112.JPG
I had to notch some of the hood structure, but nothing visible externally. I modified an intake y-pipe for a 3000gt from ebay, $20
Old Oct 17, 2006 | 10:40 PM
what size are those tubes running over the top.
ive got a bolt on 2.5 cowl hood,wondering if i could do the same thing,though id like to use a dual inlet single outlet fmic if possible this way i could run 3 inch tubing right to the tb like i did with the 3.1 motor.i dont think its possible though with twin turbos.though im thinking i could sorta use the same type of routing i did with the single turbo on the 3.1 v6
Old Oct 17, 2006 | 11:07 PM
ChobbyTA's Avatar
Car: 1987 Black GTA, 1991 Formula
Engine: 5.7L LS1, 305 TBI
Transmission: 4L60E, 5speed
Axle/Gears: Stock
Pictures
Here are some pictures of my setup.. I went with 2 T04Bs, I used Gale Banks manifolds that I found on ebay. The intercooler is from ebay also, it's a pretty tight fit infront of the radiator....
Attached Thumbnails pics needed :v8 intercooled twin turbo setups-305tpi-turbo.jpg   pics needed :v8 intercooled twin turbo setups-305tpi-turbo2.jpg   pics needed :v8 intercooled twin turbo setups-27x13x3_2in1sideout_frontview1.jpg
Old Oct 18, 2006 | 09:28 AM
[QUOTE=daves12secV6;3096120]what size are those tubes running over the top.QUOTE]
The tubes over the rad are 2-1/4 radiator hose I found on the wall at Salvo auto parts. Someone criticized them at a gas station one time for being silicone instead of aluminum, saying they'd expand under boost. I told him that when they expand they flow better!
I also made 3" fiberglass/aluminum pipes from the turbo inlets to cone filters where the highbeams used to be. I don't have any pictures of them.
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Street Lethal
Aug 13, 2015 08:28 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
