how does this cam look?
Old Feb 22, 2007 | 11:03 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I spoke with a rep from comp and we decided on this cam grind which includes a .520/.540 lift on a 236/248 duration and 113 LSA.
this will be for my 383 with procharger and 15psi aproximately.
Old Feb 22, 2007 | 11:25 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Depends on a lot of things, what heads are on the motor?
Old Feb 23, 2007 | 12:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think that'll work pretty good.
Old Feb 23, 2007 | 02:27 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
I would call around and try to get different opinions from other cam companies; cammotion, howards, bullet is a good starting place. By doing so you can get a general average of what the best cam would be, then get whatever manufacturer to grind it for you. I bought a custom ground comp cam and found out it was totally wrong for my setup because the guys at comp dont really do anything accept plug it into a computer and it does the rest, some of the other companies might have a few ideas that will add to the performance, but that cam does sound good, maybe a little light on the lift, but still sounds like a good starting point
Old Feb 23, 2007 | 11:45 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
In general, that cam looks fine for a ?Stupa'charged engine?. As to what you want out of it......who knows. What about idle, what about part throttle, what about stall speed, what about gearing, what about max HP?
Old Feb 25, 2007 | 09:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok as I explained to the tech, its more for race, but i need to cruise around as well when i want to hang with my buddies. my old 230/236 duration cam was completely streetable imo. i run a 3000stall but when my 700 gives, im going t56. gears will be 3.73 or greater depending on how long the trans lasts. and hp mark is around the 600 range. and this is with afr eliminators and a mini ram.
Old Feb 25, 2007 | 11:22 PM
What size runners on the heads?
Old Feb 28, 2007 | 10:43 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
No worries about smog police? As an ex-Californian I know that can be an issue. That cam is on the edge (smog wise), and is the Mini ram now smog legal? I dont know. Besides that stuff, the combo sounds strong.
Old Mar 2, 2007 | 01:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
195cc runners.
and no the mini ram is not smog legal, neither is myhooker long tubes or accel gen 6 dfi.
Old Mar 2, 2007 | 01:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
accel gen 6 and long tubes are not smog legal? Silly californians...
Yea, that all sounds like a very good match. It should go like crazy.
Old Apr 6, 2007 | 11:20 PM
84350twinturbo's Avatar
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
Re: how does this cam look?
for any boosted application you need a cam with a lobe seperation of 114 and up im running a 117 on my Twin turbo 350
Old Apr 6, 2007 | 11:38 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you dont need a LSA that big forced induction just runs alittle better with wider people still run 110 lsa's with turbos and S/c
Old Apr 7, 2007 | 12:30 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
117 sounds like a stock lsa, in the comp and crane cataloges, look at their blower cams, usually 112-114 and speaking with procharger, they said 113 its great.
Old Apr 7, 2007 | 10:52 PM
Transmission: th400
well im just stating what i have come accross in my research i am in college right now taking a high performance classes and when we go on the subject of turbos/superchargers and cams i made the class last an extra hour finding information about it. and that is the cam that we figured out is best for my set up..... might not be what everyone thinks but will see what the numbers are when i get it built and on the dyno at school...my high performance director has been drag racing for 30 years adn knows his stuff and he has a tt69 camaro that runs 6.59 street legal so he knows what he is talking about....
Old Apr 8, 2007 | 12:05 AM
Car: 91 RS
Engine: 350 vortec
well a wide lsa for a turbo set up is different than for a Supercharger
as a lot of scavenging with turbos can be bad but to small a LSA will also be less effecient for a S/c
And going to big with LSA will force duration lower and also limit the effecientcy of a turbo set up WRT hydrualic cams. mechanical however might not be so restrictive
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
