turning to nitrous
Old May 3, 2007 | 01:43 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
turning to nitrous
hey i was wanting to start using nitruos on my bird, im gonna run on an 1/8th mile track an im wanting an "easy" to tune and install entry level kit
heres the mods to my car, but before anything else i don't wanna hear any 305 complaining, i know i shoulda bought a 350, but my plans changed before after i built the motor
305 .060 overbore 2 peice rear main block 2 bolt
reconditioned rods
reconditioned 2 piece crank
cast pistons
#187 heads with a full port job
melling tourqe cam mtc-1 .420/.443 204/214
edelbrock eps performer intake
holley 4160 600cfm
flowtech shorty headers
flowtech y pipe
performance catback
i was thinking about the sniper kit
but im open to ideas and opinoins
Old May 4, 2007 | 03:56 PM
Re: turning to nitrous
bump, anyone?
Old May 4, 2007 | 04:19 PM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
I have always thought that stock V8 can safely take up to 100 - 125 without much difficulty
The problem with nitrous is that if you buy a small system and then get the bug - you will want to add more (as we all do)
Buy a system that at least takes you up to 125 - you will not regret it
Read around safe tuning both on this site and your instructions
trust me - its a feeling like no other !!!!
Old May 4, 2007 | 06:59 PM
is the sniper kit of any quality?
Old May 5, 2007 | 02:42 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
sniper kit is a good start, though i would go with the NX Hitman kit for about $75 more but it will probably outlast the sniper kit. in terms of solenoid life.
Old May 5, 2007 | 04:09 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
edelbrock performer.. my machinist was gonna hook me up with one of those but i kept having problems..
Old May 5, 2007 | 07:35 PM
pairtoe's Avatar
your def gonna want a wet shot. and as for the sniper kit a friend of mine bought one for his mustang and he is very happy with it, had it over a year with no problems.
Old May 5, 2007 | 08:09 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
get a throttle safety window switch , all the safety bells and whistles for your first time . It all goes boom once and you are done
for every 50 shot of N2O you back of the timeing 2 degrees
Old May 6, 2007 | 08:08 AM
thanks i appreciate the insight!
Old May 8, 2007 | 01:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I'd run a NX, Cold Fusion, or TNT kit... I've heard good things outta all those brands. I'm running a Cold Fusion kit for over a year now, problem free (including the bottle heater)...
Old May 8, 2007 | 03:04 PM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
I would say that those cast iron pistons will only last you about twenty good run down the track.
Old May 8, 2007 | 04:02 PM
Really depends on the amount of nitrous being used, and the current condition of his engine (assuming of course he has his fuel/timing issues under control)...
Old May 8, 2007 | 04:17 PM
the engine should be in good shape, but yes, i do know the cast pistons aren't gonna last forever
Old May 8, 2007 | 07:26 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
they will lat alot longer then you think..
the key is tuning. If you get a solid tune on the car and keep an eye on everything theses no reaon you cant run a 150 shot.
Run some colder plugs, get some good wires,etc..retard your timing when you plan to spray. and just make sure you dont run into detonation.
Run some good gas when you plan to spray. etc...
Old May 9, 2007 | 12:51 PM
All that plus the obvious, fuel pump. You don't want to be dropping fuel pressure in the middle of a nitrous pass....
Old May 9, 2007 | 08:26 PM
i was gonna run a pressure gauge right at the carb, probably sticking throught the hood so i can keep an idea on the pressure, plus i'll turn my regulator up when i run it
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
