check out this twin turbo setup
Old Sep 25, 2008 | 08:54 PM
project89's Avatar
yeah i know its not a street car but this is the coolest car ive ever seen
http://www.yellowbullet.com/forum/sh...ad.php?t=78141
Old Sep 25, 2008 | 10:37 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: check out this twin turbo setup
daaamn... those turbos are massive!!
Old Sep 25, 2008 | 11:58 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
jesus christ, you can stick your head inside those compressor housings!
Old Sep 26, 2008 | 12:35 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
and just to make this thirdgen related...
To Mods:
"I want to put that engine in my thirdgen car"
Old Sep 26, 2008 | 08:37 AM
firstfirebird's Avatar
Did you know that car even still has power windows? I saw a pre-release article about it. The owner bought the XLR off ebay and stripped it down.
Old Sep 26, 2008 | 08:40 AM
project89's Avatar
i read that it still had the door locks and all that didnt know it still had power windows. looks like the majority of the car and body is carbon fiber..
anyone else notice the 4 injectors per cyl
wonder what size turbos those are
Old Sep 26, 2008 | 09:11 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The pics don't show in the link? Where are the pics at? Do you have to be a forum member?
Old Sep 26, 2008 | 09:14 AM
project89's Avatar
http://i205.photobucket.com/albums/b...979/huntsville
try that junk the pics are mixed in with other
Old Sep 26, 2008 | 12:58 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Kind of scary seeing the fuel cell in the front of the car like that.
Old Sep 26, 2008 | 01:02 PM
project89's Avatar
i wonder how long those turbos will last being on that angle,everything i have ever read says that the shaft should be paralell to the ground. the way they have those mounted i wonder if the rear oil seals in the turbos will hold up.
then again to build that kinda car they got money to keep replacing turbos lmao
Old Sep 26, 2008 | 05:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Good point, but then again it looks like that engine is dry sump so i imagine the oil is scavenged from the turbos too. Especially since they are mounted so low
Old Sep 26, 2008 | 06:16 PM
mesterz2889's Avatar
well damn
Last edited by mesterz2889; Sep 26, 2008 at 06:16 PM. Reason: Automerged Doublepost
Old Sep 27, 2008 | 05:51 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Well, its not a camaro but at least its a GM product!!!
Terrell351
Jun 13, 2021 01:13 PM
bjpotter
Jan 22, 2019 12:27 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 13, 2015 08:28 PM
