got in the 9s on my second pass! TT iroc!!
Old Apr 27, 2010 | 05:51 PM
superirocz's Avatar
Only got to make two passes all day but had allot of fun. Car still needs tuned very fat tune to be safe. First pass at 13psi went 10.5@135
second and last pass with a couple more pounds went 9.9@144 liffting of the gas for the last couple hundred feet. This was full street trim on my 17 drag radial tires and heavy 17s up front and road race shocks. I have yet to touch the suspension or even tire pressure. Both launches were soft foot brake.
Here are a couple shots. Looking to get a good dyno session in and go for 8s
Attached Thumbnails got in the 9s on my second pass! TT iroc!!-ttunder.jpg   got in the 9s on my second pass! TT iroc!!-ttside.jpg
Old Apr 27, 2010 | 06:47 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: got in the 9s on my second pass! TT iroc!!
Great run have always been fascinated by turbos and the amount of hp you get out of them .
Never had one but always amazed at the time run in the quarter mile.
Are they difficult to maintain and do they have turbos for different applications such as street and race ,or is it the amount of psi that you adjust it to for increase hp gain
Old Apr 27, 2010 | 07:03 PM
superirocz's Avatar
They are all street frieldly. The truth is they are the best way to make power especialy from a reliabilty and no hassle stand point. The problem is its expensive but ounce you get everything built up you can't beat em. My car idles at 900 almost pefecty smooth and is quiet and drives like my 07 cadillac STS. I was blowing of full tubed BB car with chutes and sounded like thunder just idling around the pits.
Old Apr 27, 2010 | 07:14 PM
daverr's Avatar
very nice setup.
Old Apr 27, 2010 | 08:05 PM
irock88's Avatar
Is the install just a bolt on to the existing motor or are there modifications that have to be done , and what set up would you recommend
Old Apr 27, 2010 | 08:45 PM
superirocz's Avatar
thats were the expense comes in. There may be some bolt on kits now but when I was building it I wanted my own setup that was packaged very well and easy to work on.I ditched my AC years ago but wanted my Pwr steering. i wanted dual 3" exhaust higher than stock and it is. I made boxes under my car seats so i could run my exhaust up in the car. My ground clearence is better than stock. If you can weld then its just time. It kinda snow ***** on you but its worth it just ride in one
Old Apr 27, 2010 | 09:12 PM
irock88's Avatar
Why did you go for a turbo instead of a supercharger
Old Apr 27, 2010 | 09:36 PM
superirocz's Avatar
turbos are more effecient. No belt issues slipping, easier on the rotating assembly then a blower car.
Old Apr 27, 2010 | 10:18 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
this thread is full of win, your car and orr Z is the baddest turbo sb on this site..
keep us posted with your quest for 9s....
Old Apr 27, 2010 | 10:46 PM
irock88's Avatar
Thanks for the info and your input quite the accomplishment to be running 9s Im sure youll hit 8s
Old Apr 27, 2010 | 11:57 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Nice, do you have more pictures of your work?
Maybe twins would be next step for me?.........
Old Apr 28, 2010 | 04:24 PM
superirocz's Avatar
If you do a search you will find some of my dual exhaust and fab 9" I don't think I have any of my exhaust running up under my car seats and my new tq arm setup.
Old Apr 28, 2010 | 05:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Congrats man! PA turbo boys getting it done! That setup flys and is packaged so much nicer than mine.
What motor is in that now? What was your 60 foots? Able to foot brake any boost at all?
Old Apr 28, 2010 | 05:55 PM
Str8upChevy's Avatar
Car: '91 RS, '72 Pro/Street Z28
Engine: 305 TBI, Blown 468ci w/NOS
Transmission: 5 Spd, 2 Spd Powerglide
Axle/Gears: 3.08, 4.88
Wow, that's quite impressive,......was this your first time out in the car with the turbos?
I'm in the process of rebuilding my blown 468 and can't wait to get back out on the track. I'm hoping for mid 9's on the motor. (no nitrous)
Old Apr 28, 2010 | 06:32 PM
superirocz's Avatar
I was foot braking it but don't know if was building any boost. I only got two cracks at it and was just getting used to the new power. Both 60 foot times were 1.75. I realy didn't lean on it to much for the first two runs and that was it for the day. What were you 60 fts?
The engine is a dart little m with eagle rotating and dart pro knockoff heads and a smallish cam. accel pro-ram intake 90tb
First time out
Old Apr 28, 2010 | 07:35 PM
First time out
I was asking if it was your first time out with the twin turbos.
When I was running the nitrous it was going between 1.30 - 1.34
On just the motor it was usually between 1.43 - 1.46
I noticed you're running a 3.00 gear ratio. What was your RPM like when you crossed the line? Also, what size converter do you have?
I'm currently running a 3800 with the anti-balooning plate.
Old Apr 28, 2010 | 07:53 PM
superirocz's Avatar
first time out with the new motor/tranny. I had a weak 355 with a t56 tranny. My converter is a PTC and it seems to be working good. On the street its nice and tight. It seems to stall to about 3000-3200. Not sure what my rpm was at the end of the track.
Old Apr 28, 2010 | 08:09 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
awesome #'s for the 1s outing. Makes me wish I woulda keep my turbo seup and finished it.
If im not happy with this 383 and Novi200 Im gonna swap backto a turbos setup;
Old Apr 28, 2010 | 08:54 PM
superirocz's Avatar
Got the 9s already next time maybe 8s???
Old Apr 28, 2010 | 09:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
How many cubes?
My 60's are currently in the 1.62-1.70 range but should be getting better once i get the tune down. It has a slight rich hesitation before lighting off the turbos. No boost on my footbrake either. With the other converter I was in the mid 1.55 range at times with a best of 1.49 but it was stalling too high for my taste.
Your converter sounds tighter than mine. Mine is about 4200 but its pretty tight feeling on the street. It flashes good once you get on the gas. My max motor rpm is only about 5800 tho so far. Havent dyno'd it yet to see where the power band is. I got a feeling it may peak in the 5300 rpm but hoping its in the 5600 range.
Congrats again, thats a nice combination. Bring it to PRP sometime and we'll line up
Old Apr 29, 2010 | 07:45 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
congrats on the times that thing is nuts incredible car with those turbos and it looks like a nice clean install too great job
Old Apr 29, 2010 | 08:47 AM
superirocz's Avatar
its a 406
I would like to get out to your track this summer my friend from altoona goes there. I would be allot of fun to run them head to head.
Old Apr 29, 2010 | 08:51 AM
superirocz's Avatar
Here is an older picture of the car. This is exactly what it looked like going down the track.
Attached Thumbnails got in the 9s on my second pass! TT iroc!!-side-iroc.jpg
Old Apr 29, 2010 | 12:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Love the sleeper look of it. I want to get drag radials on my C6 wheels so it looks more street car going down the track as well.
Old Apr 30, 2010 | 12:10 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
What turbos are you using? T70 but some more info please.
How do you like them, spool time, big enough, too small and so on?
Old Dec 6, 2010 | 11:50 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
if he's running the same kinda turbo's I was, t70's, then its almost instant-on. No lag. That motor gets into boost quick. I have no doubt he will surprise you guys.
Red iroc-z 305
Sep 30, 2015 05:22 PM
downsouthboy
Aug 29, 2015 11:29 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
wruiz
Aug 11, 2015 02:59 PM
