Ping noise still here, did my mechanic put the wrong replacement cam in?
Old Mar 3, 2011 | 01:33 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Would the fact that the cam that cam out of the car was a SBC HYD HMV-278-2 and the one put in is a COMP CAMS 268H (part#12-210-2 [49]) and the RPM range, the rocker arm ratio(1.5,1.52), and pretty much all the numbers seem to be off a little.. Think maybe that might have something to do with the pinging? I found out the rest of the problem in the thread below is detonation issue and I am upgrading the fuel pump and getting larger injectors, but this pinging noise is bothering me.
my old post>https://www.thirdgen.org/forums/powe...ise-after.html
Old Mar 9, 2011 | 11:03 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Ping noise still here, did my mechanic put the wrong replacement cam in?
get a custom prom done and 42 pound injectors i found out the hard way if you are still going to use your paxton.
Azrael91966669
25
Jun 20, 2017 04:04 AM
hokis
Aug 9, 2015 03:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
