boost control on a centrifugal supercharger
Old Jun 26, 2013 | 10:37 PM
Cosmik Debris's Avatar
Has anyone here tried over-driving a supercharger and then using an electronic boost controller and some sort of valve like a wastegate on a turbo, to control the boost? It'd give a flatter boost like a centrifugal supercharger with a constant speed drive.
Old Jun 27, 2013 | 05:05 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: boost control on a centrifugal supercharger
That is very common nowadays. There was a Mustang article a few years back that essentially started the concept with a guy doing that very thing with a worked SBF running a YSI (see below), although it was already known that you could do that, it somewhat glorified it for the street racers. I know a few guys that run a Procharger F2 on their smaller LSX engines with the wastegate on the cold side, and it works extremely well...
http://www.musclemustangfastfords.co...l/viewall.html
Old Jun 27, 2013 | 05:36 PM
Thanks, I guessed it was possible and if it's possible someone will have tried it.
Old Jul 5, 2013 | 12:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
yep.. heres a good read also
http://www.gmhightechperformance.com...tegate_debate/
Old Jul 5, 2013 | 08:25 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
ProCharger just came out with basically an electronic variable over/underdrive to have some control of the boost.
Old Jul 5, 2013 | 10:00 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Nice. I know I just learned something. Thanks for sharing the link.
Old Aug 14, 2013 | 06:25 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
I liked this idea I believe he said he got 70ft/lbs more out of the car
http://www.superchevy.com/technical/...ger_wastegate/
Old Jan 13, 2014 | 10:19 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Sorry to bring up this old thread, but I have been researching this type of install and have a question about sizing of the wastegate itself.
Seems there are only theories and no solid calculations to be performed, especially when one is used with a supercharger. From what I have found so far, it is essentially based on the amount of boost you need to release and the size of the engine itself, but haven't found any solid method to use in determining what the correct size that would be needed. Some charts give the option of 44 to 60 mm for greater than 3000cc, but I would like to be a little more accurate than that.
Are there any calcs a guy can follow, or is it just a WAG?
Old Jan 14, 2014 | 11:40 AM
DIGGLER's Avatar
if you had flow data for the blower and flow data for the gate i would assume you could calculate how much you could bleed through the gate and what you would wind up putting into the intake.... and if you know those numbers along with a dyno graph of your engine, you could get a rough estimate of what power it might be making at a given rpm.
-in theory.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
