and so it starts
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: and so it starts
Originally Posted by project89
lol maybe, street lethal knows me...
- Rob
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I sure do, and I can't believe that video that I just watched. Fire? Seriously? It's obvious what contributed to it. What the heck does MS stand for in the ECM world anyway, Multiple Sclerosis lol? Dave, I cannot believe you went this long in dealing with that crap, as your fuse is just as short as mine. Get another system and be done with it already. On another note, I am glad you went single turbo this time around, and am looking forward to seeing how you set up those headers. We miss you over at e-town buddy...
- Rob
- Rob
Hey Rob - speaking of basements, I was cleaning out my dad's the other day and I found a Commodore vic20 computer, maybe you can use it to accelerate your EBL ?
-- Joe
- Rob
- Rob
not the ms's fault was my fault for the way i wired it up the injectors power, ill upload some pics here shortly , i fiished up the driver side header today and got it wraped though the wrap i bought is to damn stiff it didnt wrap really nice
header
the nice stepped vbands i bought
and the pile of other parts i bought
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Nice!
Are you using a vband for the exhaust on the turbo?
I'm tempted to weld a pipe right to my exhaust housing and using a ball/socket flange. Even the slightest pressure from my downpipe and I get a leak at the turbo.
-- Joe
-- Joe
im using the vband on my downpipe , i may give the turbine housing to a friend to cut a receiver groove in the housing to accept a stepped male vband flange on the downpipe.
if u have ot buy any vbands buy stepped assembles they seal up much much better , if u need to know were to get them let me know and ill send u a link on ebay
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
get some copper sheet and cut urself a gasket for the downpipe vband , coat both sides with a thin film of copper seal , it wont ever leak again.
The problem is the vband clamp flattens out and it can't hold the two sides together anymore. A large gap is created. I've tried a few different clamps, including a $90 vibrant one. They are all made of soft stainless.
I've got a spare 3" ball/socket flange, I think I'm just gotta weld that up to the turbo housing.
-- Joe
Car: check
Engine: check
Transmission: check
The statement that the MS is in an 'indeterminate' state is bogus, it is powered OFF. So the injector drivers should also be off, since they are not there is an issue with the design.
RBob.
Actually it is the fault of the MS system, the injector driver circuit isn't designed correctly. The fix as stated in the MS manual is a band-aid to cover the poor design.
RBob.
RBob.
it is what it is at this point , ive done a ton of ms cars, once u get past the errors in the manual , and a few small goofy things it works great
That's exactly what I did last spring. My valvecover is still full of soot.
-- Joe
-- Joe
put a couple tacks around the clamp assembly so it cant spread , they usually spread from beingover tightened
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
RBob.
RBob.
GM wired the car from the factory and had a problem.
Is it a valid argument that the MS should keep the circuit open when OFF? sure, but that was not the design intent.
Since any number of things can cause the injectors to ground the appropriate wiring would be to have them on a switched circuit, which is why I suspect GM and other OEM's do it that way.
It's too bad GM didn't use the same failsafe wiring on the fuel pump circuit. Use an oil primer with the ignition off and the fuel pump will energize. I guess that's why every procedure starts with disconnecting the battery.
-- Joe
RBob.
As Joe said, Dave wired his differently than stock, how is that the MS's fault.
And as for the MS being complicated; I have NEVER done an ecm swap, NEVER tuned a car, NEVER did a turbo install until now, and the MS was a breeze, and the car runs great. Did I mention I have never even heard of MS before my install? Seemed pretty simple to me.
-- Joe
I may do 1 stepped vband on the back of the turbo, but thats about it.
Joe, stupid question, but did you tap around the vband with a hammer while tightening?
Joe, I am also going ball and socket connectors for my next build. Though the stepped vbands look appetizing, the price doesn't.
i got mine for 11.99 each cause the seller screwed up his listing but he honored it
heres the 2.5 steped vbands 20$ for the entire assembly
http://www.ebay.com/itm/371225917756?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
not the ms's fault was my fault for the way i wired it up the injectors power, ill upload some pics here shortly , i fiished up the driver side header today and got it wraped though the wrap i bought is to damn stiff it didnt wrap really nice...
Anyway... the headers are coming out great, excellent fabrication.
MegaSquirt® EFI controllers are for experimental and educational purposes. No warranties are expressed or implied. Neither Al Grippo nor Bruce Bowling are responsible for the construction, installation, or targeted use of this unit. This unit has been tested on many engines, however, it is an experimental unit and the end-user assumes all responsibilities for its use and application. Do not use in an aircraft which, if the unit fails or ceases to operate properly, can fall out of the sky. Do not use on a boat where, if there is a failure, results in a situation where the vessel is stuck in a hurricane and sinks to the bottom of the ocean. In other words, follow the manual carefully, and seek authoritative help if you have questions. This FAQ, our manual, and our forums are solely for the support of MegaSquirt® boards by Bowling and Grippo.
Multiple Sclerosis for the win....!
i purposely locked the timing on the v6 car , it liked it.
on this car i have full timing control , and what i thought was an ignition cutout was actually false ae triggering , i had the threshold set to low so it was 2-3x ing my pulsewidth when it was triggering causing huge rich spikes.
ive got so much work to do this winter its not even funny. my columbia river mandrel bend order has been delayed 4 days now it shoudl be here today but according to tracking it still inst on the way even though columbia river called ups yesterday to fix the adress.
soon as i come up with another 100$ ill have that ultrabell/trans case and manual vb and transbrake comming from joe so i can start putting the th350 together.
and then im going to purchase an fti 3500 stall
i may dig the dana 60 out today if my tubing doesnt arive and start figureing out how im going to build a tq arm mount on it
and i still need to get the dam cage in the car, though im not in a rush with my back the way it is im in no hurry to be climbing in and out of the car but i do need to get it done before spring time
im going to try my hand at some carbon fiber door panels unless i can find a cheap source to buy big enough carbon fiber panels i can just cut to size
btw joe i have almost the full amount now r u willing to work on the price a lil bit?
btw i forgot to ask what the biggest tire i can put on those 15x8s i know the 275's fit fine
the 28x10.5's on the vs car didnt work all to well with the 8 inch wide rims .
ive got a set of 15x10's but i need a big street tire for the 15x8's
Hmm. Anyone hear about the world record 1/4 mile supra? It runs Megasquirt.
My timing isnt locked out on my car, but I am also not pushing it until I get a knock sensor. Tops 28° right now.
Hey Rob, check your PMs
New tires are much more grippy though.
Video Link: http://www.ebay.com/itm/371225917756?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'm running 16x8s with a 225/60r16 tire. I want 16x10s in the back but I also want to be able to rotate my tires. Highly doubt I can fit 10s in the front if my last tires rubbed with the 1 inch spacers. At least not without a bfh.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What are the power goals for this?
You guys must have more faith in your bottom ends than I do. I'm running a forged crank and scat sportsman rods and I'm worried that 600hp will break a rod or split the 400 block.
-- Joe
-- Joe
only thing stock thats left is the crank , and block.
the transbrake is going to make me nervous with that stock crank
one a side note i may have my tt headers sold today if i do ill send u payment for that trans stuff
theres a very expensive shotblock waitin if this one blows up
Car: check
Engine: check
Transmission: check
Well no, the fault is failing to read the manual. He wired it differently than
-- Joe
-- Joe
OK, we have already seen the consequences...
Design intent? So the intent of the design is to allow the injectors to enable with the help of a powered off MS? How do you know what the design intent is?
Sorry, I know folks like the MS system, but when there are issues such as this it really sheds a light on the system.
RBob.
Well no, if the MS is powered down it better not enable the injectors. Think of the consequences if the MS fuse pops (or is removed) and the engine is being cranked over trying to start it.
RBob.
RBob.
i do like the ms system its cheap, it does anything i could possibly want and then some, and its dead easy to tune
but some of the issues with it have been around far to long , and dont even get me started and the manual
RBob.
RBob.
its still possible for it to flood the engine with fuel, the only reason i found out is caus ei was flipping the key on and off to prime the motor since it was so cold out.
my normal starting procedure is to switch on the ignition/fuel inejctors after ive already started to crank the engine. not before like i did in the video
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
rbob is right , even if it would have had the 12v+ wired to the key like the ecm, if for any reason the ecm didnt power up , or the fuse blew it would have done the same exact thing
I don't think I'm about to throw out an ECM that has been far superior to everything else I've used in the past 10 years because of the unlikely potential that I might blow a fuse and ground the injector circuit.
Their is a reason Megasquirt is used on EVERY type of car, bike, boat, and sled you can imagine all over the Internet. It accommodates the needs of everyone and it's half the cost of the big commercial stuff.
I'm not even sure this condition can happen on mine because I'm not running the same board as you. My ECM is based on the Microsquirt module, which uses a different injector driver:
http://www.st.com/web/en/resource/te...CD00000968.pdf
I chose to do it this way because I wanted it to fit inside a '165 ECM case and I wanted a factoryish pinout.
-- Joe
Blown ms fuse = no ignition. At the most you might manage to hydrolock the engine with fuel. But, if you wire everything your own different way, anything might happen. Best to just wire it like the instructions advise. Never had an ounce of trouble out of my ms.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Some people just need something that's very basic and designed for their specific car and ignition system and set of sensors.
I, again, like the fact that regardless if I'm tuning HEI, an LS1, a buddies mustang, or a sled that my GUI and basic tuning layout is the same once the ECU is configured for the specific application.
-- Joe
Yea you can run a ms with an old type ignition which is totaly seperate. But if the pump relay is ran off the ms and the injectors are on the proper ign/start circuit there really should not be a problem.
well i hate to admit it but yesterday my tubing arrived and i was so ready to get the other header built i did the unthinkable.........
i built another ds header , i didnt relize what i had done until it was 90% welded up , when i noticed i just shut off the welder closed up the shop and went home shaking my head at such a stupid mistake. luckily only a single tube is welded to the flange . ill deal with it today somehow but boy did i feel stupid when i noticed what i did
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You can run a rear-mount in engine bay. haha
-- Joe
rbob is right...
Dude, your rushing when you shouldn't be with those headers, take your damn time. Are you intending for the final setup to resemble ZZ3Astro's, or will there be a huge difference?
Will, I got your PM, I'll shoot you one once I get back...
all fixed now , in the 2 pics thats a 3 inch intercoole rpipe showing downpipe clearance , i have room for a 4.5 inch downpipe , maybe even a 5 inch
Dave the passenger side is driving me nuts seeing it like that w/the v-band slightly pointing downward, level it properly so that they match...!!!!
Will, I just got over being really sick. It is freezing out to boot, feels like 20 below zero. As soon as I get the chance I'll grab everything for you bro...
Will, I just got over being really sick. It is freezing out to boot, feels like 20 below zero. As soon as I get the chance I'll grab everything for you bro... Thread Starter
