and so it starts
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: and so it starts
yeah more then likley i will have to goto a roller setup to get the high lift, current block would need retrofit rollers which i wouldnt trust due to being so heavy , i plan on turnning some rpm with this thing
i do have a roller block but i would have to send it to the machine shop to have it preped and bored/honed so i can reuse my current pistons in it
honestly im more then likley going to pull the engine tear it down clean it well and throw the summit cam in it so i can have the car back for the weekend , shouldnt be much damage as we caught the cam going flat soon as the car started to run funny
lol orr is right above what i want to get out of this.
id say it makes about 450hp off boost ( i didnt miss the turbos while driving it around n/a it had plenty of power more then the old engine on low boost) , dont know what it makes with boost yet , i havent had the chance to hook up the turbos yet, that was the goal this week lol
Car: 89 Iroc-z
Transmission: TH400
what lifters r u running got a link?
Car: 89 Iroc-z
Transmission: TH400
Morels! Supposively best lifter out. Can handle much higher spring loads. Supposively light solid roller type loads 200-220 seat pressure 500 open. I run 180/450.
Contact chris straub at straubtechnologies.com i think it is
Beaware they are plus .300" taller so in a roller block that has raised lifter pad you need the heads off to install them. Non roller block shouldnt have issues
thanks ill contact them ,im currently using a non roller 4 bolt block so shouldnt be an issue, even if i was using a roller block u know me im not afraid to cut and grind stuff up lol
Car: 89 Iroc-z
Transmission: TH400
Xe lobe that big i'd run 145-155 seat 375-400 open
Those morels arent cheap tho. 600$ or near that now
so far everything looks ok , not to much metal in the engine , think we should be able to clean it out well enough,
engines getting all new bearings and oil pump though its looking good for being back together for the weekend
she lives again, hopefully no issues this go around with the cam
just wrapped up the cam breakin , so far so good , deffintly going to miss the rough idle, forgot the camcorder but should get some videos up tonight as ill prolly take the car out when we go watch the fireworks tonight
more then likley the short travel ones are just shimmed under the plunger , been doing that with hyd flat lifters for years to get more rpm out of them
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Cant wait to see some more videos. What camshaft did you go with?
I just finished up the 4" exhaust on mine....and i still need to figure out the cranking pulse width for the injectors.......ill get it eventually lol
been eyeballing some prw shaft rockers , and mechanical cam setup versus the roller setup
i do miss the lopey idle
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
thats a summit 224/224 @ 50 112lsa .466 .466 lift with 1.5 rocker , id have to dbl check the cam card on the lift though
Engine: 3xx ci tubo
With those heads, it would be nice to have more lift.
What's up with the case tractor? It has been in there since the beginning of the build. Is the rear end gone?
thats why im considering the mechanical cam , i can get a cam with small duration and high lift
yeah the rear blew up in it , took a few months to track down some of the parts
now thats its grow/harvest season , not much work gets done on the farm equip since theres no time. it wont get fixed till the seaon is over
shaft rockers = ordered
mechanical cam = ordered
valve springs = ordered
who knows when ill get around to putting them in though prolly wont be till this comming winter
arc 4000d on the way
http://www.speedwaymotors.com/Platin...-161,9233.html
i know a few ppl using them without any issues or compliants figured id give them a shot, u can also grab them about 60 bucks cheaper from prw, i went with speedway incase i have any issues with them
Engine: 3xx ci tubo
Woooaaa, That top end started out cheap. How much you have into the heads & cam parts now?
What is the fancy control panel for? Figured the ECM would be controlling everything.
haha i dont wanna know
, ive spent so much money in the last few days that i honestly dont want to total it all up switch panel is for start,fuel pump,ignition,nitrous arm.
much neater wiring then wiring up my own realys to the ms
Car: 89 Iroc-z
Transmission: TH400
Engine: 3xx ci tubo
BUT...........
Everytime I price out what I would have into a Gen1/II SBC, I look at the prices for a used 3/4 ton 2002+ 2wd truck and think........for 1,500 I can have a 6.0 LQ, 4L80E, PCM, harness. Tough decision.
Your builds are well thought out economically and mechanically.
BUT...........
BUT...........
its slowly going from street car to race car lol, chute and 10pt cage is the next project , already have that stuff here just way to hot to be twisting around the car trying to weld the cage up
gota love ordering from summit , 1 day shipping since im so close
anyways heres the arc 4000d
started to wire it in tonight ran out of time
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG] Thread Starter
was going to bring the car home last night then relized i forgot to put the new plates on the car and turned back to swap the plates.
camera died on the drive home so only had this short clip to upload
overboosting by a large margin with the twins , unfortunatly i dont have room under the hood to stick a pair of t4 turbined turbos on the log headers and have them fit under the hood
so i think im going to have to dig out the up and fowards i fabbed and stick a large single turbo on it
suggestions ?
im thinking a nice 88mm will do the trick
suggestions ?
Car: 89 Iroc-z
Transmission: TH400
More flow you bypass the less turbine drive and thus less backpressure. It will control low boost if you bypass vast majority of flow with additional gates or a large one that is in proper spot.
im thinking with the location of the wastegates, you will probably need some overly large ones to be able to run low boost. and even that may not be enough. you might be able to remove them entirely and still overboost.
i also need to come up with a flow chart for the stage 3 t3 turbines , and also the gt35 turbine wheels and see what the differences will be
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by project89
unfortunatly i dont have room under the hood to stick a pair of t4 turbined turbos on the log headers and have them fit under the hood...
