F1X on BBC 88 Camaro
Old Jan 11, 2019 | 07:31 PM
landsmotorsport's Avatar
Has anyone installed a prohcarger F1X on a BBC 1988 camaro? If so, what mods will be required on the front drivers side fender? Thanks
[img]
1988 Camaro, 582 BBC Pump Gas Motor - 800 hp N/A - 4L80E, 9", Street Car
Old Jan 11, 2019 | 08:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: F1X on BBC 88 Camaro
Havent but the bbc sits forward a bit more than a sbc and it gets pretty tght in there. Might be good idea to tube front that side and gut the fender but it will need trimmed and possibly move rad forward a touch
Old Jan 11, 2019 | 08:39 PM
Yes. The fit looks to be pretty tight. Do you know any companies making a bolt in tube front for these camaros?
Old Jan 12, 2019 | 09:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I do not. For you might just need the driver side, cut frame off just in front of the strut tower and trim fender.
Probably want to go manual rack pinion steering too
Old Jan 12, 2019 | 10:14 AM
Thanks for the response. I am going to try what you said and see how everything fits.
Old Jan 12, 2019 | 02:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Best you can do is start mocking up and go from there
Old Jun 15, 2019 | 09:52 PM
Got the procharger F1X installed on the 582 BBC. Car ran good until it was on the dyno.
Old Jun 18, 2019 | 08:57 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Looks Sexy! What did it do on the dyno? lol
Old Jun 18, 2019 | 09:08 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Did turn out nice! Fit better than i thought it would
Old Jun 20, 2019 | 08:08 PM
The car made 900 hp at 5800 rpm. This was with low boost, 93 octane and a hydraulic roller cam. Engine is out of the car getting some minor upgrades. Will be back on the dyno soon.
Old Jun 21, 2019 | 07:41 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
how much boost do you plan on running ? great looking machine
Old Jun 23, 2019 | 07:31 AM
15 pounds of boost for right now. Thanks.
Old Jun 28, 2019 | 08:38 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Wow that is a clean install.. Damn..
-- Joe
Old Jun 28, 2019 | 09:29 AM
Car: 87 TA clone
Very very nice, 900hp at the wheels is pretty impressive at low boost. I thought you were going to say that the motor popped or something when you said "Car ran good until it was on the dyno."
Tbi-MAX
Jul 9, 2008 12:57 PM
ckeene502
South East Region
Aug 8, 2005 07:54 PM
smokingss
Mar 7, 2003 07:05 AM
chevyboy07 91
May 14, 2002 01:28 PM
TwigBird89
Nov 6, 2001 11:36 PM
