fuel pump question
Old Feb 14, 2019 | 11:37 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
fuel pump question
will this pump support 600 whp from a turbo 6.0 ls ?https://www.jegs.com/i/Aeromotive/027/11569/10002/-1
Old Feb 15, 2019 | 08:47 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: fuel pump question
What fuel are you planning on running? I would at minimum go with the Walbro 450lph OR the Hellcat 525 pump.
Jay
https://turbo4less.com/product/walbr...hellcat-model/
Old Feb 15, 2019 | 09:20 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Jay
will the stock lines handle these fuel pumps ? if not what size would be good ?im debating between 93 pump an e85 . the sheetz jus started selling e85 in my area
Old Feb 15, 2019 | 10:21 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Crank or wheel hp? how much Boost? On 93 i think youll be alright, def not e85. Im running a external walbro 255 and my car did 450rwhp @ 7 lbs. I would think mines somewhere around 525ish crank.
Old Feb 15, 2019 | 10:55 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
im wanting 600 at the wheels . ill do 93 if i have to . i figure sumwhere around 15 lbs of boost
Old Apr 8, 2019 | 12:30 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
For the record in my car, a single Aeromotive 340 with E85 started struggling right around 12 lbs of boost on E85. This was at a low base fuel pressure of only 40 psi through -8an braided line. Power level at 12 lbs was probably around 450-480 whp. Added a second 340 in the tank and haven't found the max of this setup yet.
Old Apr 10, 2019 | 08:49 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
It will support 600whp on gas but with very little margin. I'd go with a Walbro 450.
I'm shooting for 800whp on E85 and running dual AEM 340s in an LS1 tank.
Old Apr 10, 2019 | 09:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It is too close especially at ls fuel pressure of 58. My buddys 530 whp ls3 stroker all motorruns a 340 on gas and is barely enough it seems. It just didnt like flowing at 60 psi
on a lower base with a hot wire kit it might get close on 93. The math works since a 255 will do near 500 whp at 40 psi base. But its easier to just get a 450 lph walbro and drop in
Old Apr 11, 2019 | 06:44 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
yeah im gonna get a 450 . does walboro make one for our cars ?
Old Apr 11, 2019 | 09:24 AM
Car: 89 GTA
Axle/Gears: 4.10
Yes, but you need a good hotwire kit as they draw over 20 amps.
Old Apr 11, 2019 | 01:52 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
thanks . ill remember that when i order the pump. wheres a good place to order the complete kit . pump an hot wire kit ?
Old Apr 11, 2019 | 02:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Maybe talk to racetronix
Old Apr 11, 2019 | 02:48 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
thanks guys for the help .
Old Apr 13, 2019 | 08:05 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
yup they have it a very complete kit. i installed it last year and it was an easy install and works great
Old Apr 14, 2019 | 06:33 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
https://www.racetronix.biz/product.asp?ic=fpwh-005 THANKS GUYS I FOUND IT
Old Apr 14, 2019 | 09:06 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Originally Posted by freaky
yup
thats it
kowboy59
Nov 7, 2011 09:36 PM
Twilightoptics
Nov 18, 2002 01:26 PM
BuckeyeROC
Apr 29, 2002 07:18 PM
makinemtap
Jan 30, 2002 01:09 AM
442guy
Apr 13, 2001 04:58 PM
