Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
What's up with the 100% CPU usage on this board lately?
Old Jan 18, 2008 | 05:52 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
I have a thermostat CPU fan so it's quite noticeable when it revving. It's worst out in the main message board overview, varying wildly. It's only been this bad for the last two weeks or so. Now as I'm writing this it's constantly on 100%.. I know the animated smilies takes a lot of processor power unless one has a graphics card that relieves the CPU of such tasks, but the main overview has no smilies, only animated ads. If it's the ads, can I do anything about it? Maybe get a new computer?
Old Jan 18, 2008 | 12:38 PM
JT's Avatar
JT
Community Administrator
Re: What's up with the 100% CPU usage on this board lately?
Been discussed before:
https://www.thirdgen.org/forums/prob...?highlight=cpu
In short, it only appears to affect some members with computers. It's been that way for quite some time. If this is just a new problem to you, then perhaps you changed your system to cause this result?
Old Jan 21, 2008 | 02:36 AM
Ok, thanks.
My home computer has always had that typing delay but then it's only a 400MHz processor.
My work computer is a HP/Compaq with a 2.8GHz P4 and an Intel 82865 graphics controller with 64MB memory. Never bothering delays with that one.
As I write this (at work, no animated smilies) the CPU varies between 40 & 90% with approx 7 seconds between peaks. It goes down to 2% if I put the window down.
I notice both computers work hard when there's more than one animated smilie on the screen, so I guess the animated ads are part of the problem.
At work I don't have administrators privileges, & I don't know what might have been changed (via the network) when I rebooted 3 weeks ago.
Old Jan 22, 2008 | 10:08 AM
Ok, I guess you are obligued not to suggest removing the ads..
Guessing the animated gif ads was part of the problem I tried to change a setting.
I klicked on Tools, Internet Alternatives, Advanced, & then under Multimedia I unhooked "Play Animations on Webpages".
That solved the acute noise problem for me. There's still some typing delay, & just moving the mouse in a small circle makes the CPU run at 100% (so there's still someting heavy about the site), but at least the CPU runs at 1-2% now unless I actively do something.
Old Jan 22, 2008 | 10:42 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Have you checked to see if your computer needs some driver updating? Usually that solves wonkey computer things that are unexplainable
Old Jan 23, 2008 | 01:16 AM
Thanks for the tip! I'm afraid I wouldn't know what to look for (or where, but at least my home computer automatically updates with microsoft) but I'll show the phenomenon to a computer literate friend this weekend and see if he has any theories.
Old Jan 23, 2008 | 04:02 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Hmm! That's probably not the problem then, since a lot of drivers are on the microsoft site as well.
Old Jan 23, 2008 | 04:16 PM
gkrynick22's Avatar
Car: 1985 Corvette/Searching For F-body
Engine: 350 TPI/????
Transmission: 4+3 Manual/????
Axle/Gears: 3.23/????
Is it only on this site? I had the same problem and it was undetected spyware running in the back ground with out me knowing it.
Old Jan 24, 2008 | 10:08 AM
Yes, only here as far as I've roamed/ noticed. The network usage doesn't budge even one pixel up from 0% when the CPU happens to work hard so I doubt it's spyware. The computers at work are also quite well protected with firewalls etc.
Old Jan 26, 2008 | 12:21 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
As I sit here and type, the CPU use only spikes to about 7% when I move the mouse or type. This is is on a 2.8ghz Pentium D, 2gb ram. Running XP professional SP3 beta, and using Firefox for a browser. Its not fast anymore but certainly not outdated for home/office use with light gaming on older games.
I would try using a different browser at home if you are using Internet Explorer. Try using either Firefox or Opera and see if it makes a difference.
Your home computer is definitely on its last legs. At 400mhz I doubt you could even deal with some youtube videos, the flash compression probably requires more CPU power than its got.
Your work computer on the other hand should have no problems at all handling any web browsing.
Old Jan 28, 2008 | 02:26 AM
Yes, I'm building something better for my home use, it's not able to play youtube video's properly.. I'll try to install & use something other than IE. I noticed that the CPU is not loaded when I move the mouse over vacant areas with the ads are out of sight, but even then it's loaded when moving over text. With the ads in sight it's loaded even in free spaces.
My friend's computer noticed the same effects but not at all to the same degree, but then he has a GPU that's even more powerful than his CPU. He had some opinions of what might be the cause but I only understand so much of it to be able to recite it here.
I also noticed the fan has started revving when swapping pages in eBay now, so the bottom line I guess is getting a more powerful graphics board that'll run animated gif's etc. so the CPU is relieved of such tasks.. "Heavy/ inefficient" code I guess is only going to become more & more common..
Thanks for contributing everybody!
Old Mar 8, 2008 | 02:37 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
mines fixed pretty well now it seems, just a little bit of delay in the typing but SO much better
so far anyways
also i disabled extra things in the advanced section of IE
animations, movies, etc
changed my RAM card out for another one as well
huge improvement RE of the delays here
Old Mar 11, 2008 | 06:11 AM
Yes, something has changed on the board, the CPU usage is acceptable now so no bad delays. I haven't changed anything with the computers. But recently I have encountered another problem with the board. It takes so long to load the pages now that I can go get myself a cup of coffee in the meantime. The top of the pages loads relatively quickly, but the useful stuff takes a lifetime to present..
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Linson
Oct 1, 2015 09:50 PM
zman1969
Oct 1, 2015 11:09 AM
Royal_Z
Sep 30, 2015 08:45 PM
