Anybody use the Hedman long tubes yet or am I going to be the guinea pig?
Old Nov 7, 2014 | 01:44 AM
Podium's Avatar
Anybody running the long tube LSX headers from hedman yet? I think Im going to even though they have the flat collector. I was going to get the 1 7/8 hawks but they are really expensive (1260) shipped to me and ground clearance isnt the best. The flat collectors may make installing a starter difficult, but the ground clearance and price might be a pay off. Also my tubular k member will make it even better. Im going to call hedman tomorrow and ask about starter and oil filter fitment. Ill keep you guys posted!!!
Old Nov 7, 2014 | 01:45 AM
Podium's Avatar
Re: Anybody use the Hedman long tubes yet or am I going to be the guinea pig?
My biggest concern is heat on the starter and oil filter. I would go with the coated ones to help with that.
Old Nov 7, 2014 | 06:23 AM
Dreambird's Avatar
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
Keep us updated I am interested in those as well. I am glad they have a picture of them finally. I t does look like they would be close to the starter and oil pan but they should give extra ground clearance. Maybe a starter heat shield and some header wrap would help. I would be curious to see how they perform on the dyno as well with the unique flat collector vs. standard. BTW where did you find that picture?
Old Nov 7, 2014 | 10:02 AM
Podium's Avatar
It's on the brp hotrods website. The only in car one they have.
Old Nov 7, 2014 | 05:38 PM
Pocket's Avatar
Car: 91 Trans Am
I saw the car in person. They fit great, excellent ground clearance
Old Nov 7, 2014 | 05:52 PM
Podium's Avatar
I talked with Jeff today. Very nice guy. He is going to email me pics next week of the headers in their shop car. It's a third Gen formula. I think this is the route I'm going to go. I had hawks 1 3/4 back in 07 with my other build. I remember how bad they were banged up due to the bad clearance.
Old Nov 7, 2014 | 08:52 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Go for it..i think they might perform well actualy.Im using the cheapy ls swap headers and even with the design flaws of the ports and the welds etc..i gained nearly 20hp/30tq over my stock 02 fbody manifolds. These look alot nicer(in pics atleast) and flow shouldnt suffer.I want to see the test of time on them and if they have any leaks/warpage like mine did.The starter I think would be ok but oil temps might be an issue.
Old Nov 7, 2014 | 09:00 PM
Podium's Avatar
Thanks for your input. A mini starter is in order. I talked to Jeff and he said with the coated headers heat isn't a problem. They have a track car with many miles and the heat isn't an issue. He did tell me that changing the oil may dip oil on the edge headers if you don't prepare for it. I may run a summit relocation kit . It's under 50 bucks.
Old Nov 9, 2014 | 12:17 PM
Podium's Avatar
Pics!!!!
Old Nov 9, 2014 | 01:12 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Where do I get a set of those engine mounts for an sbc?
Edit:
I just traced all that back through everything and found them for sale for $300... Jeeez.
Old Nov 9, 2014 | 01:16 PM
Podium's Avatar
Filter is in same location. Starter is a pain. Those mounts are from BRP. I doubt they have them for an sbc though.
Old Nov 9, 2014 | 04:35 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Those do look rather cool under the car lol.
Old Nov 10, 2014 | 07:46 AM
WTR388's Avatar
Car: 87 Trans Am
What's the part number on these?
I checked the hedman site (no pictures, really??) and then checked the hedman part numbers on Jegs and they have the same picture for the different long tubes, and they don't look like these ones.
What is the price on them and from where??
Old Nov 10, 2014 | 08:20 AM
V8SC1987's Avatar
Car: 1988 Camaro Iroc-Z Convertible
Axle/Gears: 8.8 with 4.10 Gears
Part numbers and prices are included in the link below.
http://www.brphotrods.com/products/3...cts/index.html
Old Nov 10, 2014 | 04:19 PM
V8SC1987's Avatar
I saw the BRP Hotrods firebird at LS Fest this year. Too bad I didn't get a better detail shot of the headers installed.
Old Nov 10, 2014 | 05:29 PM
Podium's Avatar
A side shot would be nice to see how low it fits from rail. I might just get the hawks 1 3/4 LTs again. Im not liking buying a new starter and how they sit under the car.
Old Nov 10, 2014 | 06:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Axle/Gears: MWC 9” 3.00
I also seen them on a ls3 swapped car. Looked to fit well but changing oil filter may get alittle tight but theres room
Old Nov 10, 2014 | 06:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Old Nov 10, 2014 | 06:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Old Nov 22, 2014 | 09:21 AM
zoidberg355's Avatar
Car: 1983 Camaro
Engine: LS7
Transmission: TH350
I`am trying to decide between these and ssw 1 7/8 headers. Stainless headers would be nice but after the shipping and taxes Hedmans are ~1200$ and stainless steel works ~1700$
Are Hedmans coated from inside and how long are coated headers lasting? I don´t have starter motor and motor mounts yet so that´s no problem and oil filter relocation kits are just ~50$.
Old Nov 22, 2014 | 12:54 PM
Pocket's Avatar
Car: 91 Trans Am
Some companies offer lifetime warranties on the coating, not sure what BRP offers. Driving conditions affect life, such as do you drive it in the snow/salt and leave it dirty or is this a garage queen that sees the sunny side of life only? Early example may get 5 years of abuse, the latter will likely never fail over the life of the car
Old Nov 22, 2014 | 02:06 PM
Car: 1983 Camaro
Engine: LS7
Transmission: TH350
Car will be driven mostly in summer weekends and sees sometimes rain. i don´t have garage but an carport. If they last over 5 years and could be recoated it would be great
Old Nov 22, 2014 | 03:13 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Is the engine crooked or is that just the floorpans?
Anyone have some pictures of these on a car with SFC's?
Either inner or outer?
Old Nov 23, 2014 | 06:46 PM
Podium's Avatar
Well I'm not going to be the one to try these. I bought the Hawks 1 7/8 Stainless. I'm never going turbo and when I go stroker these will work well. These will be the last headers I buy for this car. Famous last words......
Old Nov 23, 2014 | 11:09 PM
Car: 1992 Camaro RS
Our engines are offset to the passenger side.
Old Nov 27, 2014 | 04:06 AM
jay7199's Avatar
is that a truck intake on the BRP Hotrods firebird?
Old Nov 27, 2014 | 12:53 PM
Pocket's Avatar
Car: 91 Trans Am
Yes, the later cathedral intake. They have a RAI hood for clearance
Old Nov 30, 2014 | 12:02 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Hmmm, those are different, I like the clearance. I saw them on the BRP site but wanted to see pics. Might try them instead of their mid-length headers. The one thing I hate, gonna have to ditch the Spohn TA.
Old Nov 30, 2014 | 09:41 AM
WTR388's Avatar
Car: 87 Trans Am
Will I need to change out my starter to a mini starter then? That may affect my choice in headers if that's the case.
Old Nov 30, 2014 | 08:15 PM
Podium's Avatar
I think so but would call them to make sure. I deleted the email so I cant tell you for sure.
Old Dec 26, 2014 | 07:49 PM
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Anyone use the Hedman headers though?
Old Dec 30, 2014 | 12:05 AM
Podium's Avatar
Members have used the mid lengths and love them.
Old Dec 30, 2014 | 11:48 AM
92BLKL98's Avatar
Does anyone have any front and side views of the long tubes showing ground clearance?
Old Dec 30, 2014 | 12:01 PM
Dreambird's Avatar
Engine: 6.0l LQ4
Anybody use the Hedman long tubes yet or am I going to be the guinea pig?-3rdgenheadr2.jpg
Anybody use the Hedman long tubes yet or am I going to be the guinea pig?-3rdgenheadr1.jpgClick image for larger version
Old Dec 30, 2014 | 12:10 PM
92BLKL98's Avatar
HMMM still very low.
Old Dec 30, 2014 | 12:23 PM
Dreambird's Avatar
Engine: 6.0l LQ4
Yeah I am still up in the air about them myself leaning towards the mids
Old Jan 5, 2015 | 12:26 AM
WTR388's Avatar
Car: 87 Trans Am
Dang, I wanted to use those but I'm not too sure with how low those sit... Canadian roads suck.
Old Jan 5, 2015 | 10:36 AM
92BLKL98's Avatar
Yeah I think I am going to order the mids for my build.
Old Jan 5, 2015 | 11:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Dont rule out a shorty or midlength. They make power. Just not sure if any fit our cars yet
Old Jan 5, 2015 | 11:49 AM
92BLKL98's Avatar
These are made for Third gens.
Old Jan 7, 2015 | 01:56 PM
Guest
Guest
Posts: n/a
I am using them on my build. Just waiting for them to be delivered. I will post my pics.
Old Jan 7, 2015 | 10:56 PM
johnw999's Avatar
I have the hedman longtube headers, but I'm still a long way away from the install. This is a post I submitted a while back:
https://www.thirdgen.org/forums/ltx-...1983-92-a.html
Old Jul 11, 2016 | 06:38 PM
johnw999's Avatar
Hmm - I found this review on summitracing.com .
Purchased for my 87 camaro with fbody ls1 -Factory k member -Umi performance solid mounts and brackets These do not work with factory k member regardless of what mounts used. I could not get them to bolt up to my motor when it was connected to my k member EVEN WHILE MOTOR IS ON A STAND. They interfere with the k member not with the mounts. Without the k member they bolt up but...... Header primary is 1" away from oil drain plug, so oil changes will cover your header in oil and splash everywhere. The collector makes reaching oil filter impossible without removing header. I Will be returning mine.
I wonder if an oil filter relocation kit is necessary. The headers are supposed to be used with Hedman's LS engine mounts, and that probably solves the k-member interference issue.
Old Sep 27, 2016 | 03:14 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Dang, I really liked how these looked. I have read though that the Mid-length headers are only slighly less powerful than the Long Tubes so you're not truly losing much.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
