TPI bits wanted for mehasquirt conversion in the UK
Old Dec 21, 2014 | 12:50 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Hi all.
I have a 1991 RS Camaro with a 1977 350 block in it. I am about to start out on a megasquirt fuel injection conversion, but need a few things or for someone to point me in the right direction.
I need everything TPI from the heads up - intake, plenum, throttle body, fuel rails, injectors, thermostat housing, all sensors with it (TPS, CTS, etc) including the connectors and a sort pigtail of wire from each.
Also the throttle cable and fuel rail unions and short length of pipes attached to them.
Unfortunately I am in the UK and we haven't much scrapyard pickings here!!
Can anybody help?
I know its a lot to ask, but...................
Andy.
Old Dec 21, 2014 | 04:19 PM
Pocket's Avatar
Car: 91 Trans Am
Re: TPI bits wanted for mehasquirt conversion in the UK
I have everything you need. Cant guarantee the injectors work though, but thats a small part
Need a set of serp accessory brackets?
What year are your cyl heads for? Intake bolts changed angles for older heads
Old Dec 21, 2014 | 05:17 PM
Car: 91 camaro rs
H Pocket.
Thanks for the reply.
The heads are early ones also (70's) with the non angled centre bolts. Although I am hoping I can just elongate the holes. If necessary I will TIG weld up the mods required.
May also need a dizzy, but have an early one that triggers an MSD box.
Do you think you have all the bits? Is it MAF or MAP?
Any idea how much you would want?
Its important that I get the connectors and pigtails with the sensors, and the short section of fuel line. Really tough to get it here.
PM me please.
Thanks.
Andy.
Old Dec 21, 2014 | 05:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I also have a 91 tpi top end
Old Dec 21, 2014 | 05:59 PM
Pocket's Avatar
Car: 91 Trans Am
Ill check out what Ive got. Might have an older TPI unit. I know Ive got the harness bits, plus any extras you might want like HO2s. Think Ive got a complete fuel system still and can cut the lines off so you'll have the necessary fittings
Old Dec 21, 2014 | 06:30 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I was cleaning up around here to make some space last week and reached deep enough thru my stuff to be able to reach this set-up again:
https://www.thirdgen.org/forums/engi...injection.html
The price includes the parts pictured, however; I've also got some other small TPI parts available separately too like the throttle cable bracket, throttle cable, distributor cover, ECM, Camaro Air box, (and so on) if you need any of that stuff too. (Sorry - can't help with wiring)
This stuff is pretty heavy and I'm sure that shipping to the UK would be a bit expensive. If your SERIOUSLY interested jut let me know and I'll get a shipping quote for you ASAP.
P.S. It might be best to ship all these parts in 2 packages to avoid potential damage when shipped.
Old Dec 26, 2014 | 03:43 PM
Car: 91 camaro rs
Is the PM system working? Sent messages out to 2 members and they are not appearing in my inbox?
Andy.
Old Dec 27, 2014 | 09:52 AM
John in RI's Avatar
I got your PM Andy,.....will be sending you a reply in a few minutes.
Old Dec 27, 2014 | 03:24 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have an accel superram setup with throttle body, Fuel rail, injectors... the full superram setup, and I am in England as well.
Picking up this superram setup would be a pretty good gig for you since you would save loads on shipping!
Old Dec 28, 2014 | 10:20 AM
Car: 91 camaro rs
Hi Bullydawg.
Would you PM me some more details please?
Or preferably, email to andyfanshawe@aol.com, since I can't PM you for some reason.
Thanks.
Andy.
Old Dec 28, 2014 | 10:57 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
PM sent.
customblackbird
Aug 15, 2021 10:16 PM
stalkier
Aug 13, 2015 12:59 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
