Green wire coming out behind engine near heater box...?
Old 04-21-2018, 08:28 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Sorry about all these wiring posts!! So close to starting my car.
1983 Firebird, was a V6 car.
This wire is coming out of the harness that plugs into my heater box.
Any idea what it goes to?
Attached Thumbnails Green wire coming out behind engine near heater box...?-20180421_173414.jpg
Old 04-21-2018, 08:47 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Green wire coming out behind engine near heater box...?
Looks like the temperature sender for the gauge , if the wire is dark green . (lower left of this diagram)
Attached Thumbnails Green wire coming out behind engine near heater box...?-fig12_1983_body_wiring_continued.gif
Old 04-21-2018, 08:57 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yeah the temp sender wire comes out of the C100 (bulkhead) connector. But I do appreciate the guess!
Old 04-22-2018, 04:46 AM
Twin_Turbo's Avatar
3 possibikities
Fan switch pass rear head
Ac clutch
Ac on fan control (fan on with ac control on)
Old 04-22-2018, 04:54 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Hmm, definitely could be AC stuff, but my car didn't have that option, and the plug it shiny like it had been connected. I don't think there were any electric fan options in 83, were there?
Old 04-22-2018, 06:20 AM
Twin_Turbo's Avatar
Post a pic
Old 04-22-2018, 06:42 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Sure I can take any pics that'd help. What exactly? My first post shows the plug, and the harness. The harness comes out of the firewall behind the passenger head, and has the connections for the blower motor.
Old 04-22-2018, 07:32 AM
Twin_Turbo's Avatar
Oh pic didnt load on app for me. Its light green. I dont think v6s have an ac throttle kicker. Must be from a thermostatic vac valve or sensor. Does it go into the loom under the ac box that runs to the ecm. It goes through the pass side a pillar behind the kick panel
Old 04-22-2018, 09:27 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Connection for checking Carb dwell ?
Old 04-22-2018, 01:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A LT GRN wire that is part of the HVAC control goes to two places. The pressure cycling switch on the receiver/dryer and the idle stop solenoid. Wrong connector for the A/C pressure switch, but easily the correct connector for the idle stop solenoid.
If the wire reaches the carb that would be my guess.
RBob.
Old 04-23-2018, 06:35 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Thanks guys! Knew we'd get it figured out. I pulled the V6 thinking I labeled everything but... never the case.
So, with a non computer controlled motor that has an Eddy 1406 on top... how do I connect this wire? Or do I not need to? What does the Idle Stop Solenoid do?
Wish I could CTRL+F on my FSM! So hard to search for things in that big book.
Old 04-23-2018, 06:52 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Though it seems I'm reading the Idle Stop Solenoid is to idle up with the AC on, is that correct? I have a non-AC car, and this plug does appear to have been connected somewhere.
Old 04-25-2018, 01:13 PM
83 Gman's Avatar
Idle stop solenoids can be used to close the throttle plates on a carb when shutting off so the engine doesn't diesel. You set the idle with it activated and have minimum set point with it without power.
Another thing it could do is raise idle speed with the A/C on also.
Old 04-25-2018, 03:10 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That is my understanding, that it ups the idle speed when the A/C is on. It being a non-A/C car it was likely not used. Since it looks like it had been connected, maybe it was but not to the correct location.
RBob.
Old 04-28-2018, 07:47 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
RBob, that logic works for me. I'll revisit this when I finish the engine swap if something isn't working!
Old 04-30-2018, 05:49 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ah HA! Maybe this pic will help!! This was the connection that the green wire USED to go to. Black plug that had three wires. This green wire coincided with a yellow on the other side of the plug. Black was ground. Blue had no mate on the other side of the plug.
Old 04-30-2018, 09:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
HVAC wiring. Look at the diagram that OrangeBird posted, top center. The LT BLU wire goes to the P/S pressure cutout switch. Which then goes on to the A/C compressor clutch.
This causes the A/C compressor to shut off when P/S pressure is high, such as when parking at low speed. Prevents the engine from stalling due to the added engine load from the P/S pump.
RBob.
Old 04-30-2018, 11:22 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
OK, so the LT BLU not having a connection on the other side of the black 3-wire plug makes sense then.
And the LT GRN has to be the IDLE STOP SOLENOID for the AC, also not needed.
Sounds like my heater controls will work OK after all.
Thank you guys for helping, OrangeBird that diagram was a big help!!
Now to figure out what those last two wires are... V6 to V8 wire question
alexquade
09-03-2011 06:22 PM
Fast 383
01-15-2010 08:17 AM
azcamaro
04-14-2007 09:44 PM
Crusin' 1980's
04-03-2006 06:55 PM
HamSpiced
04-28-2003 01:11 AM
Quick Reply: Green wire coming out behind engine near heater box...?
