flaring ?
Old Aug 13, 2002 | 06:25 PM
JMDinHawaii's Avatar
flaring ?
I just got my new prop valve, I did the plunger mod and I am about to put it on. Problem is that the lines are going to need re-flared. I have a double flare on them now and I'm not sure if its going to work. My flares are concaved, those are double, right? How do I go about getting a flare that kinda comes to a point?(kinda looks like an arrowhead) Is this a single flare?
Anyways I'm not sure how to do this. Can I use the same flaring kit that I do double flares with?
I wish I had pictures to describe this better
Old Aug 13, 2002 | 07:15 PM
ede's Avatar
ede
you need a differant tool. snap on sells them either off the truck or their web site.
Old Aug 13, 2002 | 08:55 PM
anyone know the name of this different type of flaring tool??
Old Aug 13, 2002 | 10:04 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
What year is the car?
Old Aug 14, 2002 | 12:11 PM
86 TPI
Old Aug 14, 2002 | 01:59 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
I believe all of the brake flare lines on a stock F-body are ISO Metric Bubble Flares. That might be what you want to make. A standard double flare is made with the special tool by using the die as the first step and then using the tip of the press itself as the second step, thus a double flare. That's probably what you see now. I have one question though, why is there double flares on the line now??
Tom
Old Aug 14, 2002 | 03:33 PM
I did a rearend swap from drum to disc and the donar car was an 83 camaro. When I went to change the prop valve it had double flares on it...I don't know why. So I cut the lines and double flared them. Now that I decided to go with the new valve(which I should have done in the first place) I have to re-flare them back. Are the IOS flares hard to do? and does craftsman make this tool?
Old Aug 14, 2002 | 06:49 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I suggest replacing the brake lines. The ISO "bubble flare" is such a pain in the butt, that even I do not attempt it. The kit to produce the ISO "bubble flare" is cost prohibitive as far as I am concerned.
Find a doner car and remove the brake lines you need. I know it is a big pain replacing the brake lines, especially the front to rear brake line. But in the end it is easier. Or at least it is my opinon it is easier.
Thanx,ANDYZ28
Old Aug 15, 2002 | 06:02 AM
ede's Avatar
ede
yeah the bubble flare tool cost right at 100 dollars from snap on. lot of real parts (not auto zone) store carry adapters to go from bubble to the old double flare
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
billybob6110
Feb 11, 2016 10:41 AM
romcjr
Sep 17, 2015 05:18 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
blue86iroc
Sep 11, 2002 04:16 PM
