Brake Line
Old Nov 3, 2002 | 02:16 PM
86TATpi's Avatar
Brake Line
The brake line going from the front of the car to the rear axle broke yesterday. I was wondering how long of a line that is because the parts store said they don't have preset lengths. I haven't had time to take it all apart yet so any help in the matter would be appreciated. Thanks
Old Nov 3, 2002 | 07:13 PM
MD83Z's Avatar
When mine broke I just bought a flaring tool and spliced in from the broken spot back to the rear axle T.
Old Nov 3, 2002 | 10:06 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
A change in the brake lines was made in 1984 to an "ISO metric Bubble flare" which is very difficult to reproduce.
I would suggest getting several pieces of the "Bubble Flare" brake line in premade lenghts and some unions from the auto parts store. Then fit the to the car as needed.
Thanx,ANDYZ28
Old Nov 3, 2002 | 10:56 PM
86TATpi's Avatar
I'll try that, thanks for the suggestions.
Old Nov 4, 2002 | 07:17 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
question though, the factory line is bigger than 3/16-metric quivilent & smaller than 1/4" . wont there be a lot of movement inthe connector going to the rear brake hose? Mine just broke there too .
I work @ AZ & the only ISO bubble linee is the "british" metric line which is smaller dia than the stock. or when the line is properly torqued, it will not leak & this is a dead issue.
edit: MD83Z, wouldn't it have been easier just to have Pat Goss ( of Motor Week) fix the ride
Old Nov 4, 2002 | 07:49 AM
MD83Z's Avatar
I wish Pat could have helped stop my car last friday when the brake hose blew.
Old Nov 4, 2002 | 08:18 AM
ANDYZ28's Avatar
Car: 1982 Z-28
At the time when you buy the different lengths of ISO metric bubble flare brake line. Also buy several ISO metric bubble flare unions. These unions are specifically designed to allow the brake lines to screw into them properly.
The connector to the rear brake hose also has the "bubble flare" to allow the brake line to connect properly.
Thanx,ANDYZ28
Old Nov 7, 2002 | 06:32 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Try classic industries they have pre-made brake lines for our cars.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
