is it possible to do this...
Old Aug 13, 2003 | 05:50 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
is it possible to convert a thirdgen over to a 4th gen rack and pinion? id be using a tubular K member, and welding the brackets to it. it sounds doable but are the tie rod ends compadable?
Old Aug 14, 2003 | 05:04 AM
ede's Avatar
ede
yeah it can be done. someone sells a k member that can use a rack system
Old Aug 16, 2003 | 09:03 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
is that PA racing?
Old Aug 16, 2003 | 09:20 PM
iroc22's Avatar
Whats the reason for wanting to swap?
Old Aug 17, 2003 | 10:27 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
i think it will be lighter and have less parts to wear out versus the stock setup.
Old Aug 17, 2003 | 07:35 PM
iroc22's Avatar
Generally racks are associated as being the heavier of the two...
Old Aug 17, 2003 | 09:49 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
hmmm
Old Aug 17, 2003 | 10:02 PM
laiky's Avatar
heavier than a recirculating ball steering box, centerlink, idler arm and 4 tie rod ends??. The alluminum racks i've worked on were pretty light, not to mention there are fewer parts in the steering system to wear out.
Old Aug 17, 2003 | 10:06 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
thats what i was thinking. an aluminum rack versus all the arms and linkages and the steering box. id say the rack is higher.
92firebirdguy
Sep 1, 2016 07:53 AM
luvofjah
Sep 26, 2015 08:28 PM
Blue419
Sep 10, 2015 01:03 PM
Thaney9
Aug 7, 2015 08:25 PM
CD MaroMan 91
Mar 13, 2002 04:15 PM
