Do SS brake lines actually lower stopping distance?
Are stainless steel braided brake lines actually beneficial? Do they really help stop quicker? Do they give a different pedal feel, etc?
i know what the box says, but as you know, most manufacturers like to make their products sound better than they really are. If you can already lock your brakes up how can these help?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
by giving you more control so you can stop without locking your brakes up.....atleast thats one way..
they also increase efficency... the volume of the system isnt changing because of line flex...
mostly, they feel better under your feet... and from that, you can work the pedal better and stop better...
i dont have them on my car yet, (like a idiot, i keep putting off brake upgrades on my car in my search for power) but when i put them on my motorcycle, WOW.
you really FEEL the diff... its amazing.
Car: 91 Camaro Vert
what do you mean by "you can feel the difference?" Can you explain a little further what you felt?
know how you can feel the tires contact patches thru hard braking? how you can tell thru the pedal when a tire is on the edge of lockup and how hard you can press before it goes?
they highten the feeling...
its like running your gloved fingers on the desk.. you can feel the drag on the desk.... then taking the gloves off.... you're still feeling the desk, but you can feel it better......
because of the increased feedback, a good driver can really cut closer to lockup without going over.... and the pedal makes you feel more confidant as you do it too..
its not going to help if you just slam on the brakes.. and its not a solution for bad brakes, but it does help you get that lil extra out of driving your car....
also, because you arnt pushing harder to make up for the flex in the lines, the pedal is easier to push... and the easier it is to move, the easier it is to modulate on the edge of lockup.
Car: 83Z28 HO
Transmission: G Force 5 speed
Originally posted by MrDude_1
[B]they also increase efficency... the volume of the system isnt changing because of line flex.../B]
I know stock lines (rubber coated) ones tend to "bulge" out slightly due to the hydralic pressure.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
If your stock rubber hoses are old, you'll probably notice a difference just installing new rubber hoses.
Car: 83Z28 HO
Not saying Justin is wrong, but let's review the original question:
The box may say decreased stopping distances, but who knows the condition of the rubber hoses they were using. Comparing SS hoses to old rubbers ones is not a far comparision. New rubber must be compared to new ss hoses.
Transmission: A4
