installing swaybar bushing ?
Old Mar 10, 2004 | 01:09 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
Is this a straight swap = remove old & replace with new?
Do I need to remove the end links? They were just replaced a couple of weeks ago.
Thanks for the help!
Old Mar 10, 2004 | 01:47 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Re: installing swaybar bushing ?
Old Mar 10, 2004 | 05:35 PM
CaysE's Avatar
I think Zerstorer is trying to say yes. Unbolt both bushing shells from the frame, drop the sway bar (it will be hanging from the endlinks... you can take it off of the endlinks if you want; you'll probably want to clean the sway bar where the new bushings will go), apply grease to the bushings and on the sway bar, pop on the bushings (they should have a slit to open the bushing and pop onto the bar), then bolt it all back up. 15 minute job if you're good and have the right tools. Put aside an hour if you're a novice.
Old Mar 13, 2004 | 01:42 PM
azcamaro's Avatar
Done!! (yesterday)
Took me a little over an hour. Not bad for a girl, just learning how to work on my car myself. Yeah, I'm pretty impressed with myself.
Old Mar 14, 2004 | 04:19 AM
b-man's Avatar
Car: 91 Z28
Engine: 5.7
Transmission: TH-700-R4
Slit goes to the front, in case you didn't know.
Old Mar 14, 2004 | 06:58 AM
azcamaro's Avatar
Got it, thanks.
My car no longer squeeks when going over speed bumps
Old Mar 14, 2004 | 12:52 PM
CaysE's Avatar
good job
Old Mar 14, 2004 | 01:38 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
You mean I have to do it again. Damnit.
Old Mar 14, 2004 | 10:30 PM
b-man's Avatar
Car: 91 Z28
Engine: 5.7
Yup, won't be hard since you've done it already though. Sucks when I do something like that.
Old Mar 15, 2004 | 10:27 AM
CaysE's Avatar
I have yet to understand why it matters where the slit goes. If the bushing is thoroughly greased, it shouldn't matter.
Old Mar 15, 2004 | 01:48 PM
azcamaro's Avatar
don't you know ALL slits go in the front!
Old Mar 15, 2004 | 01:50 PM
b-man's Avatar
Car: 91 Z28
Engine: 5.7
lmfao!!!
Old Mar 15, 2004 | 01:53 PM
b-man's Avatar
Car: 91 Z28
Engine: 5.7
He said "thoroughly greased".....I like them like that!
Old Mar 15, 2004 | 04:09 PM
CaysE's Avatar
I suppose it depends what position the bush is in. I mean bushing.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
