Ways to improve my 60 foot?
Old Apr 5, 2004 | 02:08 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I would like to run 1.8 60 foots and I know I have the power but I can't get it to the ground. I have a lot of spinning off the line unless I take off real slow. My best so far with a manual trans and 255 streets is 2.1. This was my setup for those runs:
Lakewood LCA's
All else stock
I am going to the track this weekend and here's what I plan:
Poly Torque arm bushing
Poly Trans bushing ( prothane)
Poly panhard bushings
BFG Drag Radials at about 20 psi
I know I should get a Spohn torque arm but I am looking for a way to get traction quick and I am getting these things at a local speed shop this week. What other "tricks" can improve my 60 foot time???
Old Apr 5, 2004 | 02:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
take off your front sway bar.
get either some drag radials, ET streets, or slicks.
then try again... if you're getting wheelhop (you'll notice it easier in the burnout box then at the line) then get some LCA relocation brackets.
the swaybar alone should cut a tenth off that. (cheap too)
Old Apr 5, 2004 | 02:23 PM
GASGZLR's Avatar
I have Drag Radials that I am going to use next time. If I remove the sway bar won't my car handle real bad? I have to drive 75 miles to the track on curvy roads and on the interstate and I don't want to wreck, but it's good to know that about the bar.
EDIT: I can't remove it at the track either, I have to run how my car leaves my house.
Old Apr 5, 2004 | 02:28 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
its not as bad as you would think.
when you touch the gas, the front drivers side lifts more, but thats about it.
under normal driving, or even under emergency swerving, you're ok.
just dont go fooling around on curvy roads, or autocrossing.
try this: take the bar off tonight, and just drive around the block.. get a feel for what i mean.. it wont make it undrivable.. it'll handle like a 70s land barge, but its perfectly fine for SANE street driving....
normally, i run as she sits on the street... keeps be slower since im in a vert that doesnt have a rollbar...... but when i go all out, i take mine off before i goto the strip, and put it on when i go home
every serious drag racer in the local Fbody club has theirs off all the time...
the diff will amaze you if you havent done it before.
Old Apr 5, 2004 | 02:39 PM
GASGZLR's Avatar
I have no will power! LOL, I am prolly gonna take it off cause I'll do just about anything for that extra tenth at the strip. Thanks!
Old Apr 5, 2004 | 07:13 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
why does removing the front swaybar help in the ET's
Old Apr 5, 2004 | 10:14 PM
MdFormula350's Avatar
better weight distribution = better 60 foot = better et.
the front end lifts more at launch letting the rear end squat down and tha puts more weight to the rear tires for better hooking.
Old Apr 6, 2004 | 12:28 AM
89' RS/blue's Avatar
Car: 1989 RS Camaro
also get some adjustable drag shocks for front, and set them to super soft.
Old Apr 6, 2004 | 02:21 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
call me silly but ive even gone corner carving in my car that happens to have no front sway bar and all kinds of drag racing specific mods
honestly it handled pretty good. I outran a ford focus on the twisties if that tells you anything
Old Apr 6, 2004 | 09:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
call me silly, but i do the same thing.
im still drifting on the edge of traction, the only diff being that instead of drifting at 70, im doing the same corners around 50..
but im a idiot and wouldnt reccomend anyone to attempt driving like that.... lol.
honestly, im probly going to buy spohns big sway bars in a lil while.... but i have higher prioritys first... i like turning too much to leave the bars off all the time..
Old Apr 6, 2004 | 11:08 AM
GASGZLR's Avatar
MrDude, could I just unbolt my endlinks from my sway bar at the track and leave the sway bar on? Will it be fine just hanging on from the main bushings?
Old Apr 6, 2004 | 11:48 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
yea you can do that... ive done that before too.
i just started taking it off because its weight on the nose of the car.
btw, if you havent taken them off yet, get a scrub brush and clean the grit off the top of the endlink bolts, then spray some WD40 on them before you goto take them off..... otherwise the grit makes it hard to take off.
Old Apr 6, 2004 | 02:07 PM
GASGZLR's Avatar
Thank YOU very much!
Orr89RocZ
Feb 13, 2016 10:04 PM
Americanmouse
Sep 7, 2015 12:10 PM
fasteddi
Sep 2, 2015 10:29 AM
EFR2000
Aug 18, 2015 08:54 PM
