Rolling the lip? Do i need to?
Old Jun 2, 2004 | 06:18 PM
raptere's Avatar
Car: 1991 Camaro Z-28 (Durango R/T)
Engine: 383 L98 W/ HSR
Transmission: 700R4 Tuned Shift 2600 Stall
Axle/Gears: 3.73 10Bolt Posi W/ Al Cover, Disks
Is rolling the outer fender done to keep the lip from cutting the tire, or is it done to actually geve an extra quarter inch of clearence for the tire, does the tire ever even get that far through the susspension travle? Also so you worry about the section with or the tread with for getting all of the way out to the fender lip?
Will i have to with 15x8 inch rims with 4.5 back spacing and 275/50-15 tires? what about 5.0 inch back spacing?
Old Jun 2, 2004 | 08:41 PM
WickedMaro's Avatar
Car: 1988 Camaro Convertible
U will be fine, dont worry about the fender i run a 275-60-15 drag radial and a soon to be 28 12.50 et street and all my clearance problems are fine
Old Jun 2, 2004 | 09:10 PM
raptere's Avatar
so i should be all good with the 4.5 backspacing?
and i am looking at drag radials ive heard the bf goodrich have better traction , but the nitto drag radials are actually longer life, just sacracice a little traction
What have you guys heard and experienced with these sets of rubber, and which sounds like it would be best for my application a daly driver and weekend warrior. car in the sig.
thnks guys
Old Jun 2, 2004 | 11:39 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
If your spinning through 3rd with your mods something is up. You shouldn't have that bad of traction problems with your mods.
I would get a set of nittos and some LCA relocation brackets at least for now.
Buddy of mine runs 8.7's in the 1/8th mile with a stock l98 with free mods, headers (rest of the exhaust is hacked up stock stuff), and LCA relocation brackets. He leaves the line pretty hard with VERY little or no spin.
Old Jun 3, 2004 | 06:21 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
i had to roll my fender and some to fit my 26x11.5 ET's *on a 15x10 rim w/ 4.5" backspacing*
Old Jun 3, 2004 | 12:42 PM
raptere's Avatar
sry i meant i was spinning through third because of really bad track conditions, not power, just the time i posted wasnt accurate. but what exactly are thoes things you described and what do they do?
and you vote is for nitto, interesting, ok
thanks
Old Jun 3, 2004 | 01:03 PM
raptere's Avatar
ooooo, lower controll arms, i just looked it up. so yea it says they help traction but while looking around they also showed their torque arms and actuall lower conltoll arsm to also help improve traftion, will sub frame connectors help any too?
Old Jun 3, 2004 | 09:44 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Subframe connectors will always help a 3rd Gen. They should be the first improvement to any Cam/Bird!!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
shanelique22
Oct 3, 2015 07:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
