Starts to shake a 70 mph.
Old May 25, 2005 | 08:25 PM
Abubaca's Avatar
I'm starting to detect a shake at around 70 mph. It's blatantly obvious by 75, and almost undriveable by low 80's.....which I haven't done since I found this problem.
The car feels fine up until 70. The tires were rebalanced just in case last weekend and all were within tolerances, except the right front which was 1.75 ounces off. All are now balanced and the problem didn't go away.
Unfortunately since it doesn't see much highway driving, there's been a L O T of work done since I last did any high speed cruising. New(used/rebuilt) tranny, new (used) driveshaft, new (used) 9-bolt, as well as all new steering linkage, STB, springs and shocks.
Someone suggested swapping front wheels off my S10 to see if it could be bent rim. I guess even a balanced front wheel can shake at highers speeds if it's bent.
....any suggestions? Things to check? I REALLY don't want to start throwing parts at this especially since the entire front end just got put back together.
Old May 25, 2005 | 08:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Did you have the driveshaft balanced?
Old May 25, 2005 | 09:49 PM
Abubaca's Avatar
Driveshaft is what I'm thinking too (for the record)
....When I was doing the tranny swap at my buddy's house, we noticed that my original DS was really corroded and the UJs were a bit rough. He said he had one out of a parts car that was in much better condition. At the time I didn't think much of it since it was clearly in better shape.....
...but to answer your question, NO! I just assumed, and we all know what that does
What kind of shop do I call to have it done? And do you think it's really likely that the DS is my problem? Obviously you can't be sure, but is that common?
Old May 25, 2005 | 09:54 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I had the same problem in a Honda civic when I hit 80 mph. I had an alightment job, and the problem was solved.
Bill
Old May 25, 2005 | 09:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's possible, the balance on the stock steel shafts wasn't that great to begin with. You'll need to take it to a driveline shop to get it balanced.
Old May 25, 2005 | 11:53 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
If your driveshaft and u joints check out ok, you might want to check out your torque converter too.
My 98 Tahoe would shake pretty bad at 65-75 mph, and it would shudder at 45 mph in OD with the TC locked. When I tapped on the brakes to unlock the TC at 45 mph the shuddering went away. My guess is the clutch lining was badly worn causing an imbalance at high speeds whether the TC was locked or not.
Long story short...a new TC cured all. You mentioned your tranny swap, did you get a new TC with it? It sounds like a long shot but I was going nuts for months trying to figure out my Tahoe's problem.
Old May 26, 2005 | 07:19 AM
Abubaca's Avatar
Yep, it came with the tranny. Not brand new, but less than 5000 miles.
...I'm hoping that's not the problem!
....but that's the right excuse for the T56
Old May 26, 2005 | 09:29 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i have experienced where bad front rotors would cause higher speed shacking, aligment, tires, tire pressures, balanced tires/rims, driveshafts, u-joints
from the various types of vehicles thats what i came across
if i felt the shake in the seat of the pants/floor boards, turned out to be driveline related/broken mounts, worn mountsou run it in
if you run it in neutral at those speeds and it goes away, then thats where the problem lies.
if it was more in the steering wheel feel of the shake, turned out to be more front end related (alignment, suspension like tie rods, rotors, and of course dammm fix-a-flat in the tire)
geezzzzzz
i've expirienced all this, i am getting old LOL
ohhhh yeah
various makes and models too
and on my 79 TA
subframes helped some too......
Old May 30, 2005 | 06:20 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hi Chris...look into the driveshaft. I had the same vibration on my RS. I swapped to a LS1 aluminum shaft and it went away. That would be my first move.
Ed
Old May 30, 2005 | 12:18 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
Vibration problems I have had on my car
1. drive shaft, havn.t cut one open but I have been told that the factory one had a sound dampening material in it. it eventually comes loose and the drive shaft can't be ballanced very well. I had my drive shaft ballanced and a week later the problem came back, nasty vibration at higher speeds and it got worse when I let off the gas. I noticed that when I let the car sit a while it was worse. took the drive shaft out and stood it on end all winter once, no vibration problems for about 3 weeks. get a new drive shaft if you have these problems
2. warped rotors (done this a lot with my stock brakes) vibration gets worse when you step on the breaks
3. flat spotted tires, two causes 1. leaving the car parked all winter 2. locking up the brakes
4. tire wear problems / tire delamination in my case not getting it aligned after replacing the idler arm I wore the inside edge on a tire bad and it kinda bubbled you couldn't see it but you could feel it with your hands and definatly feel it at speed
hope this helps
Ryan
Old May 31, 2005 | 03:23 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Sounds to me like thedriveshaft is 180 off on the rear....The driveshafts and the yoke on the rear were painted yellow on 1 side...if you put them 180 out of sync it will vibrate @ ~70
Old Jun 2, 2005 | 05:02 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
well if its not the driveshaft which it probably is... my car shook real bad at about 70mph + and i put it on the lift and my sway bar endlinks were almost totally gone... that might be your problem but i doubt it b/c if you have been under it that much looking for the problem then you would have noticed it b/c the endlinks are kinda obvious.
Old Jun 3, 2005 | 10:00 AM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
I'd say either driveshaft, bad tire or bad balance. The bad tire might have belt coming loose and some tire techs miss it if it's not too severe. Or the balance may need to be done within an 1/8 oz. instead of the usual 1/4 oz. This was a fix for my Neon that did the same thing at around 70-72.
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
xxx3man`
Sep 23, 2015 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
86White_T/A305
Aug 17, 2015 12:16 AM
