need help with tire replacements
Old Jun 6, 2005 | 05:30 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
I need some new front tires and the ones I have on there now are 235 / 50 R 16. (I have 1985 IROC-Z rims)
I'm having trouble finding new ones in this size. Some ppl on this site have 245 and 255 etc. What would be a good replacement, and what do the different numbers mean? What is the differences between the different sizes?
thanks
Old Jun 7, 2005 | 05:06 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
I believe that the big number - 235,245 etc. is the tyre width in mm. The other number is the profile. This denotes how high the sidewall of the tyre is, expressed as a percentage of the tyre width. (50% etc.so for 245 50, sidewall = 122.5). The third number, no doubt you'vre realised is the rim diameter in inches.
Cheers,
Mark.
Old Jun 7, 2005 | 07:00 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Factory stock size for the 16" IROC wheels are 245/50/16. These are common and I would forget about that odd ball size you have now.
Old Jun 10, 2005 | 01:34 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Could I put some 225/xx/16's on there?
Would that be better, to have skinnier tires up front>?
Old Jun 10, 2005 | 01:54 PM
DJP87Z28's Avatar
Why??? Just go with the stock look since you had the wrong size before.
Old Jun 13, 2005 | 03:47 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Yeah but I'd rather have skinnier tires up front. I don't really want them to look thick and bulky like the rear ones.
Anyone else run a 225 on an IROC rim?
Old Jun 14, 2005 | 12:22 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
if you want to run 225 up front then go with 225/60/16 it is the same height as 245/50/16 just skinner put it like this if you want to go skinner bur stay the same height add 10 to the first number and subtract 5 from the second number really easy just like the mustang have 245/45/17 is the same size as 245/50/16 but i would go same size all the way around it looks so much better but if you dont i would put 235/55/16 that would look alittle better just a tad bit smaller hope that helps Daniel
Old Jun 14, 2005 | 12:30 PM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
Just posted my 3000 mile review of the Falken Zeix ZE-512s I put on my 'bird.
https://www.thirdgen.org/techbb2/sho...hreadid=303999
Really like them, and they were reasonably priced compared to other tires in the same size.
Old Jun 23, 2005 | 04:19 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Ok I did manage to find a 235/55 r16.
This might be a bit taller than my 235/50/ r16 that I have up front. What do y'all think. Will it be noticable?
Old Jun 23, 2005 | 04:37 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Please don't use his method or his punctuation (or lack of).
Do a google or read this
An no 245/50/16 are not the same size as 225/60/16 nor are 235/55/16. I'm just talking height wise too, they are close but not exact.
245/50/16 is a 25.7 inch tall tire while a 225/60/16 is 26.6 inch tire.
And yes a 235/50 will be shorter than a 235/55 and people that look closely will notice.
Vintageracer
Jan 10, 2020 05:33 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
mizz0313
Aug 12, 2015 06:45 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
