Need help to Lower Ride!!!!
Old Jan 3, 2006 | 01:06 PM
outcast45's Avatar
Car: 91 Camaro
Engine: 305 TBI V8
Transmission: 5 speed
Hi I have a 85 RS Camaro and it has basically stock everything. I need to know how many inches the original springs are and what size of springs should I get to lower the car? Any Ideas ? I would really appreciate help on this.
Old Jan 3, 2006 | 01:33 PM
LAN_Lord's Avatar
Car: 1989 v8 305 TBI Camaro
Engine: 5.0L 305ci V8
Transmission: Stock/ TR400 or whatev
Hey, im new around here, but my camaro is lowered. It's a 1989 RS Camaro. It matters if you have a V8 or V6 too, just so ya know. But get the eibach sportline's that's what i used. Lowered it about 1.8 inches all the way around. But I also replaced my shocks and struts at the same time when I did it. I replaced them with KYB, non-adjustable. I've been happy ever since, my car handles excellent now, and it isn't too low, I can still make it over a majority of speed bumbs with no problems.
Check out the link for explanation
http://eibach.com/cgi-bin/htmlos.exe...65099000004627
also check out pics to see how low it is....
www.tejasoutfitters.com/89CAM.jpg
www.tejasoutfitters.com/89CAM1.jpg
www.tejasoutfitters.com/89CAM2.jpg
Old Jan 3, 2006 | 01:39 PM
outcast45's Avatar
Car: 91 Camaro
Engine: 305 TBI V8
lowering ride
How much did that cost you and what shocks and struts did you get? Was the job difficult ? Ive never done anything suspension wise though I have changed a rear end before..
How many inches does your ride sit off the ground ?
Old Jan 3, 2006 | 02:27 PM
LAN_Lord's Avatar
I bought KYB GR-2's is what they were called, ran me about 450$
The rear shocks are a piece of cake, but the front struts are a bit tougher, you'll also need to unbolt your sway bar, and move your spindles freely, so make sure that you have it lifted pretty high. Me personally, i got to use the lift at midas here in town......no jack stands needed!
Old Jan 3, 2006 | 02:28 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
the rear is cake, the fronts are tough, imo. ebmiller i think has good site, do a search and follow his instructions.
Old Jan 3, 2006 | 02:29 PM
Diggler86's Avatar
Car: 86 TA
wow posted that a minute apart and used same terminology..
Old Jan 3, 2006 | 02:45 PM
outcast45's Avatar
Car: 91 Camaro
Engine: 305 TBI V8
Wow
What are the price range on somethin like that is 450 the cheapest or most expensive middle ? I guess maybe I should try to redo the bushings on the front sway bar and the rest and see how that goes if it doesnt seem to hard ill dig in more hehe. Thanks so much for all the information!
Old Jan 3, 2006 | 03:02 PM
LAN_Lord's Avatar
Oops! $450 for eibach springs, KYB shocks and struts. That was my total cost, I'm really not sure of the individual prices......
Old Jan 3, 2006 | 03:06 PM
Diggler86's Avatar
Car: 86 TA
you'll also want LCA relocation brackets. say $70 plus welding.
Old Jan 3, 2006 | 03:09 PM
outcast45's Avatar
Car: 91 Camaro
Engine: 305 TBI V8
lowering ride
LCA brackets what are those used for ? ok 450 for it all thats not bad.
Old Jan 3, 2006 | 03:25 PM
Diggler86's Avatar
Car: 86 TA
corrects the geometry of the rear control arm after lowering.
Old Jan 4, 2006 | 12:50 AM
Gr89RS's Avatar
Car: '02 Z06
Re: Need help to Lower Ride!!!!
Personally I think the sportlines look better but remember eibach also offers the prokit, with a drop of about 1.3 inches.
BTW, there's no such thing as an 85 RS.
The base model camaro's in 85 were the sport coupe and berlinetta.
J-money
Jan 4, 2019 09:45 AM
Magman
Aug 2, 2016 08:32 PM
jbates346
Oct 21, 2015 01:50 PM
Linson
Sep 21, 2015 01:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
