Wonderbar
Old Apr 4, 2006 | 08:31 PM
TJC8974's Avatar
Car: 85 IROC/First Year Of The "Roc"
Engine: 305........for now
Transmission: 700R4/Corvette Shift Kit
Wonderbar
I Recently put a steering brace on my maro from TDS, the "wonderbar" , and one of the bolts on the passenger side didnt line up right so i had to leave it off, it works fine without the bolt no squeaking or vibration or anything just wondering if anyone else had the same problem.
Old Apr 4, 2006 | 09:23 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
mine lined up perfectly.
Old Apr 4, 2006 | 11:33 PM
TJC8974's Avatar
thanks for the reply....anybody else have any trouble????
Old Apr 4, 2006 | 11:41 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
no problems with mine either, everything lined up perfect.
Old Apr 5, 2006 | 12:22 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Did you tighten the bolts on other side completely before you tried installing the bolt on that side? That can make it so you have no play to work with. Then try lifting it with all the weight on the suspension, not the chassis. Either way leaving that one bolt off is unsafe and you might regret not putting it in.
Old Apr 5, 2006 | 12:45 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It would depend on which bolt he left out. I'm going to guess it was one of the outer two bolts, since they have a tighter hole compared to the slots for the two bolts that secure the sway bar mounting brackets. If that is the case, then leaving out one of those bolts, while not ideal, would be no different than if he were using one of the other aftermarket versions which lack that extra mounting bolt location. If it were me I'd loosen it again and see if you can move it enough to get that bolt to engage. You could slot the holes slightly on both sides of the brace if you need a little extra movement to fit that bolt.
Lon
Old Apr 5, 2006 | 08:40 AM
REDRIGHT9's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I also got a TDS wonderbar on my car...Lined up perfectly...If so many people had them line up well, I would maybe be concerned about the frame on the car...Maybe a side got tweeked just a smidge. Do you know of any minor accidents with the car?
Old Apr 5, 2006 | 09:55 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Mine too lined up perfectly
Old Apr 5, 2006 | 10:10 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I had the same problem that you did (with the passenger side bolt not lining up). I loosened the driver side bolts a bit and just kept trying to that that bolt in...eventuyally i did but it was a PITA. If all else fails, try removing all the bolts and get that one in first... (Did you notice that there are 4 bolts on the passenger side but only 3 on the driver side?)
[IMG][/IMG]
Old Apr 5, 2006 | 10:48 AM
TJC8974's Avatar
yeah i did notice that, and if you look at ur picture its the top right bolt, thanks yall ill try taking it off and reinstalling it, ill let u know how it goes
.........and whats PITA?
Old Apr 5, 2006 | 11:09 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
mine fit perfectly also
Old Apr 5, 2006 | 08:31 PM
Car: 1988 SC Camaro
Engine: 305 TBI
"Whats PITA?"
If i saw that (PITA) a few months ago, I wouldn't have know what it meant, but i found out since then that it stands for "Pain in the ***."
Old Apr 6, 2006 | 04:44 AM
TJC8974's Avatar
oh ok thanks............
Old Apr 7, 2006 | 07:07 AM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
I'm another one who had no problems aligning the bolts, hope it works out for you.
Old Apr 7, 2006 | 02:49 PM
Stevo's Avatar
Car: Pair of 92 Z28s
i DID have problems with my passenger side outter bolt going in. I was in a rush and didnt put it in...My driver side went in. On my gf's car all bolts went in smoothly.
We both have TDS wonderbars...I havent got around to getting that last bolt in either its an extra one anyway...
im curious about my frame though.
Old Apr 7, 2006 | 03:13 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
on my 86 it all went in fine. on my GTA i had to push on it to get it in.
Old Apr 8, 2006 | 04:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Does flipping the bar over make a difference? I think I remember looking at mine and it didn't look like it would go, then I flipped it over and everything lined up perfectly. Anyways, I had no problems with my TDS bar either.
Old Apr 8, 2006 | 04:52 PM
kaptinkafeen's Avatar
Could possibly be, but I think TDS puts the decal on the face of the Wonderbar that should face DOWN (towards the ground). It is (or is it) possible that the decal that sais TDS was put on incorrectly and thus when you fliped it over it fit?
My WB went on o.k. It was the darn new stabilizer bar brackets that I had to fiddle with. I ended up having to bore one of the bolt holes out on the R side bracket so that the bolt would line up with the chassis. No big deal though....
-Andrew
Old Apr 8, 2006 | 05:40 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
when its face up the bolt didnt line up on one side, but if you turn it over it fit perfect for me.
Old Apr 8, 2006 | 08:47 PM
TJC8974's Avatar
Im pretty sure i put it on correctly, looks just like the picture in crusin 1980's post. I think I just need to mess with it a little bit I just haven't got around to it. Thanks again for the info guys................
Old Apr 8, 2006 | 09:34 PM
Car: 1988 SC Camaro
Engine: 305 TBI
[IMG][/IMG]
Old Apr 8, 2006 | 10:19 PM
TJC8974's Avatar
Im off tomorrow so im gonna go under and try to line it up, if i cant get it ill just bore the hole a little with a drill bit, ill snap a pic before and after and post it tomorrow
Old Apr 9, 2006 | 05:32 PM
Stevo's Avatar
ya thats what ill end up doing if i cant line it up next time i get under the car.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
