Whats causing this noise??
Old Sep 16, 2006 | 07:09 PM
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
hey,
I have a really annoying noise coming from the rear end of the car. Whenever i go over a bump, i get this popping sound coming from there. Even if i am going really slowly over a bump it makes the popping sound. I was wondering what the source of this noise?
Thanks Alot in Advance
Old Sep 16, 2006 | 07:50 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
sway bar mount mabe, also check the drivers side LCA bushings
Old Sep 16, 2006 | 07:59 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
sry but the noise is coming from the rear end, i shoulda posted that before.
Old Sep 16, 2006 | 08:02 PM
Engine: 383
that's what I was refering to....I ment to say the rear sway bar mounts, and the LCA's go from the back of the rear "frame"(if U can call it that) to the rear, also you might want to see if an exauast hanger broke and the exauast is hitting somthing when you hit a bump
Old Sep 17, 2006 | 11:33 AM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
thx for the reply, i wasnt sure what u were talking about. (my stupidity) When I get a chance, ill check for those and see whats going on.
Old Sep 18, 2006 | 01:25 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Mine does that on the driverside. I changed the wheel bearings and it still does it. I think the shaft is shot. Is it on one side or the other?
Old Sep 18, 2006 | 05:03 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
well its just on the drivers side, it only happens when the car hits a small bump.
Old Sep 18, 2006 | 06:42 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Jack up the rear of the car and wiggle the wheels and see if they make the noise. I can put my hands and 9 and 3 o'clock and wiggle and it makes the same noise. Mine does it when I hit small bumps too. If it's a quik bump it does it but if it's a longer bump it's fine.
Also, check your shock mount, control arm mounts, panhard mounts. Make sure everything is tight.
Old Sep 18, 2006 | 06:46 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
sounds like a plan, im going to get my car on a hoist later this week for other things and i will check the rear and see whats goin on.
HoosierinWA
Oct 7, 2015 10:15 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
