how much power?
Old Jan 21, 2007 | 08:58 PM
mr iroc's Avatar
Car: 88 iroc
Transmission: 5 speed
Axle/Gears: dount know
how much power?
i have a 88 iroc im puting a 350 maybe a 383 in it i also have t-tops so my ? is even with sub frame coector how much power can my car realy handel befor i twist the chass? what elts can i do to make my car handel more power?
Old Jan 21, 2007 | 11:41 PM
Kandied91z's Avatar
and have what happen to it? with 300+ mark i started to get stress cracks in the roof of my hardtop... t-top i can only imagine. depends though on if your going to the track or just around town. if it's an around town only car just use less sticky tires. can twist a car as easily that way.
Old Jan 23, 2007 | 10:44 PM
mr iroc's Avatar
Car: 88 iroc
any 1 have ideas on how to make it any better
Old Jan 23, 2007 | 11:22 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
First of all subframe connectors should be required even on the V6's.
Now as for how much HP before you you twist it with SFC's. Look at my combo in the sig. My subframes are starting to twist the unibody...
Old Jan 23, 2007 | 11:27 PM
mr iroc's Avatar
Car: 88 iroc
i know i need sub frame read 1st post also what do u have doune to your 355 what sub frames do u have?
Old Jan 24, 2007 | 07:51 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
sorry forgot sig... here you go. I have umi SFC they are one of if not the best out there. My SFC are perfectly fine... the car is now the weak link
Old Jan 24, 2007 | 08:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
How much power before the car twists? Why don't you ask one of the guys on the drag racing board, they're the ones with the REALLY high powered cars. SFC's is pretty much all you need, over 500HP and you should have a safety cage. There are some very high powered 3rd gens around that aren't twisting their chassis', see what their secret is.
Old Jan 25, 2007 | 01:31 PM
Shagwell's Avatar
Car: projects.......
...my 11 sec vert doesn't have any twist issues.....
Old Jan 25, 2007 | 05:24 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
The only issues I have is that the SFCs are actually pushing into the floor. I am still investigating the cause.
Old Jan 31, 2007 | 01:21 PM
Shagwell's Avatar
My "sfc's" are actually 2x2 box tubing notched through the floor. Welded full length and stuffed inside of the subframes at front and rear with extra bracing, plus my 8-point cage. My connectors are more of an "in floor frame".
Old Jan 31, 2007 | 02:18 PM
joshmack's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 377: comp 10.5:1
Transmission: 350 turbo- 8 inch Coan
Axle/Gears: 10 bolt-373
im running low 11s 10s this year forsureand just have subframeconntecors and t-tops. all Throttle no Bottle
Old Feb 3, 2007 | 09:00 PM
mr iroc's Avatar
Car: 88 iroc
what type of sub frame would you reconmend weld in or bolt on whats the pros\ cons of each also i see some are round and some a scware which are better
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
