Everybody with MT ET Streets....
Old Sep 19, 2007 | 09:54 PM
9secz28's Avatar
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
I just got a set of 15x8 pro-stars with 5.5" backspacing. I am not sure what rear tires to run. I want to run either 28X11.5 or 26x10.5 or larger if they'll fit. Does anyone have any pics of there cars with these or larger tire sizes on them and the mods they had to do. I tried a search but didn't come up with what I was looking for. I want them to tuck up into the fender and not sure how big I should go! Thanks in advance!
Old Sep 20, 2007 | 08:40 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
Re: Everybody with MT ET Streets....
i have the 26x10.5. they fit with no mods. i have them on 15x10 prostars with 5.5bs. i dont think that i have any pics of them right now. but ill look to see if i do have any. next set i get is going to be the 28 inch ones. they should fit. i dont use these tires on the street, they are just for at the track.
Old Sep 21, 2007 | 07:02 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
5.5 with a 8 inch rim, it`ll be tucked, that`s for sure! The 28 will need the wheel wells hammered to make room, maybe even the bump stops with that combo of width and backspace. 26 er`s will be the closest size to stock.
Old Sep 21, 2007 | 07:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
5.5 backspacing is kinda tucked in...better suited for 4th gen rears as they stick out wider. this is what i now have, a wider 4th gen rear with a 15x8 with 5.5 backspacing. I'm running a 5/16 inch spacer too tho as i need that to help clear the ls1 brakes
but i have 26x10.50 ET Streets on those wheels and they are tiny. i used to have 26x11.50's on my 16 inch Irocz's and they had over an inch of tire tread to them. I know i dont push alot of power but i hope i still hook as good with this tire. i wouldnt run 10.50's on 10 inch wheels.
Old Sep 21, 2007 | 09:14 PM
slownlowgmc's Avatar
Car: 83 camaro/98 gmc
Engine: 350/350
Transmission: 350/4l60
Axle/Gears: 4.10/3.42
what size wheel and tire are you running greezemonkey
Old Sep 21, 2007 | 09:51 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
15x10 with a 5.5 bs or get a 15x8 with a 4.5 bs. I have the same rims and tires above and I run a 15x10 so the tires doesn't look puckered.
Old Sep 22, 2007 | 06:33 AM
15x10 w/ 5.5 backspace, The tire in that picture is a Hoosier QTP 29x11.50
Old Jan 6, 2008 | 11:29 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
i have to ask though since i keep getting different answers from everybody
with a 15x10 and a 5.5 backspace plus 28x11.00 or 28x11.50 will i need to modify my wheel well
thnx
1988TransAm22s
Feb 20, 2010 05:25 PM
Orr89RocZ
25
Sep 4, 2007 08:39 PM
3GTAs1TA1Z28
South West Region
Feb 11, 2006 10:29 PM
Sinful One RS
Jul 7, 2001 09:58 PM
