spring compressor to lower car?
Old Dec 7, 2007 | 03:53 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Has anyone used these small spring compressors to lower our cars? They look like they might work....http://cgi.ebay.com/ebaymotors/ws/eB...175420729&rd=1
Old Dec 7, 2007 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: spring compressor to lower car?
probably not a good idea
Old Dec 7, 2007 | 07:33 PM
wdigitog's Avatar
Why not?
Old Dec 8, 2007 | 11:27 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Hard bump, like a pothole or something may just pop those off the spring and BAM! You've got stock ride height on one side and lowered on the other. Would probably have the same effect as jumping you're car a couple feet off the ground.
Old Dec 8, 2007 | 12:50 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
No.
Old Dec 8, 2007 | 10:17 PM
Guest
Guest
Posts: n/a
You're supposed to use 2 per spring, and clamp a pair of coils together. They arent going to come off on their own, but... they'll both slide around until they're next to each other over time.
Old Dec 9, 2007 | 07:44 AM
wdigitog's Avatar
MadMax...have you tried them? Is that what happens? Did it increase the spring rate alot? Too stiff?
Old Dec 9, 2007 | 10:26 AM
Guest
Guest
Posts: n/a
I didnt notice much aside of lowering the car. Its far from the right or ideal way to do things, but it works. If you can find a way to keep them from sliding that would be good. I never came up with anything.
Old Dec 9, 2007 | 11:20 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Everything about this thread screams "bad idea".
:twocents:
Old Dec 9, 2007 | 03:42 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
:twocents:
It may work, and I'm not saying it doesn't, just that it seems to have a chance of being dangerous.
Old Dec 9, 2007 | 03:45 PM
Guest
Guest
Posts: n/a
Why? Think two small bolts cant hold a couple coils together? Only problem would be rust over time.
Old Dec 9, 2007 | 04:07 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I just meant that if the spring is put under heavy compression the coils might hit the pieces that are holding the coils together... that would cause snap over/understeer. Bad news if you aren't expecting it and are in a turn. And, there is a chance that the bolts might work off one and not the other and the spring would be off-kilter.
Old Dec 14, 2007 | 07:18 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I've seen those things at the auto parts store. I wouldn't do it but it's your car.
Azrael91966669
25
Jun 20, 2017 04:04 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
novaderrik
Aug 10, 2015 12:44 PM
anesthes
Aug 8, 2015 09:37 PM
Thaney9
Aug 7, 2015 08:25 PM
