bilstein struts installed pics
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i purchased moog iroc style springs from spohn
i also purchased bilstein struts and shocks
i never didd suspension before.
can someone post installed pictures with the tires out of the way with your bilstein front struts installed please
do stock front springs work with bilstein struts?
i thoguht they did but now im doubting myself
any help would be great thanks
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: bilstein struts installed pics
If its a stock replacement strut, you should be fine. IIRC these cars came with bilstein from the factory, albeit a much older version. But even the new yellow and blue ones should hook up fine.
You might want to look into cutting the moog springs. From what I have read, if you cut them just right, they are basically equal in ride height and spring rate to the Eibach Pro-kit springs. Also, you might wanna look into replacing the strut mounts with aftermarket ones while you are in there, because it's a PITA and you are gonna want an alignment after anyway. Plus the stock mounts are prpbably worn.
Axle/Gears: no idea
thanks
my concern is with that the front bilstein have these cup like rim around it like its going to support a spring, which is what i thought was stock but after lookin at old pictures of when i installed new rotors i see the front stock spring in-bedded behind the stock stut not on top
im just confused and im afriad i bought teh wrong setup.
even thoguh it said 82-92 bilstein strut/shocks
plsu i was told the moog iroc style springs were a good stock replacement
Axle/Gears: no idea
sorry i learn most from pictures. these manuals seem to skip steps.
anyone out there have any suggestions. i tried to google images and i get nothing close to pictures of springs installed or struts. this isnt the fun part
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the iroc replacemetn springs are a good replacement. problem is that they sit way high, they gave me about 4" of fender gap.
as for the struts, i dont think they whould have a large cup on top of them.
these are not bilsteins, but koni's, they should look similar, ignore the coil-over springs
Engine: LO3
I think that some people might use those struts to make coilovers - hence the spring mount (if thats what it even is). I would give spohn a call, they should be able to tell you about them.
The stock springs (and most lowering springs too) sit in between the control arm and the K-member, while if you go to coil-overs, which alot of newer cars have, the spring would go up top to the strut mounts.
Axle/Gears: no idea
sry guys my bad i just double checkd no cup for coil oveer on my front strut
its been so long since i bought them i startted confusin my self
its a regular stock replacement direct bolt in
so how should i go about cuttting the springs?
i just want regualr stock height so nothing fancy for lowering
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My experience with Moog IROC-style replacement springs is as follows: The fronts (5662) are great. They didn't noticeably change the ride height. However, the rears (5665) jacked the car up higher than I like (though many might not complain at all). Even with the OE insulator removed and replaced with radiator hose, I'm dissatisfied. I'll probably cut a bit.
JamesC
JamesC
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
