weird stance after suspension rebuild
Old May 22, 2008 | 11:33 AM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
i just rebuild my entire suspension on my 85, and replaced all the springs with moog replacements, but now my front end sits super high, the bottom of the flare on the fender is about 6-7in off of my tire, and it just doesn't look right at all, will my springs settle? also i have the stock 15x7 wheel with i think 215/65/r15 tires, i haven't driven it but 5 miles yet, so after some time, will the springs settle? or should i just go buy the pro kit?
Old May 22, 2008 | 11:57 AM
jminton's Avatar
Car: 1985 IROC
Engine: 305 4bbl H.O.
Transmission: WC T-5
Re: weird stance after suspension rebuild
make sure you didn't install your sway bar upside-down. mine sat that high and it turned out that the sway bar was supporting the body.
Old May 22, 2008 | 01:37 PM
Car: 85 camaro
Axle/Gears: 342
nope sway bar is correct
Old May 22, 2008 | 01:42 PM
jminton's Avatar
Car: 1985 IROC
The springs will settle a bit, but not that much. Did you index the springs to the A-arm? And are the springs properly seated in the upper pocket?
Old May 22, 2008 | 01:44 PM
eeeeeefirebird's Avatar
if your stock springs were super worn out and sagging alot, your car was probably already dropped a little bit, then putting fresh springs actually raised it. ive heard of people putting prokits on their cars and the car being the same height haha
thats another thing is making sure the springs are seated right, it makes a huge difference if the spring is lined up with the bottom hole on the a-arm and if its lined up right with the upper insulator.
Last edited by eeeeeefirebird; May 22, 2008 at 01:45 PM. Reason: Automerged Doublepost
Old May 22, 2008 | 01:46 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
did you index the springs so they sat properly in the lcas?
Is there an engine in the car? lol
Old May 22, 2008 | 08:07 PM
Car: 85 camaro
Axle/Gears: 342
nah i just like to drive my car on my hopes and dreams, yes theres an engine in the car! haha anyways, i just made sure the end of the coil was in the correct spot top and bottom, so unless they somehow moved, which they didnt, their in the correct spot, i have kyb gr2's if that matters at all, and i cant figure out why this thing looks like a mud truck in the front! the backs not all that much better but its not quite as bad as the front
Old May 22, 2008 | 08:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the springs are not indexed properly. Its common for the front of the car to sit way high if the are off.
Old May 22, 2008 | 08:24 PM
jminton's Avatar
Car: 1985 IROC
Proper index for the springs is that the end of the spring is in between the 2 smallest holes in the a-arm.
Old May 22, 2008 | 08:29 PM
Car: 85 camaro
Axle/Gears: 342
two smallest holes where on the a arm?
Old May 22, 2008 | 08:39 PM
Car: 85 camaro
Axle/Gears: 342
well i just went out and measured it, but i didn't pull a wheel off to look at my springs as im about to go to bed, but from the ground to the top of the front wheel well is 28 and 1/4 inch and for the back its 28 inches, so i guess their about right, but it just seems to sit so high, are those numbers high?
Old May 23, 2008 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've read that 27 1/2" is factory ride height. Using Moog fronts on my car, the height is not quite 27. The rear sat so high I trimmed a bit of coil.
JamesC
Old May 23, 2008 | 01:29 PM
Car: 85 camaro
Axle/Gears: 342
well i pulled a wheel and saw that the end of the spring was not quite in the pocket, it was about one inch past the pocket, so i it it with a piece of pipe until it was at the second hole, well in the pocket, but thats as far as i can get it without compressing the spring a bit, which i didn't have compressors with me,
and get this, it was 28 1/4,.... well now its sitting at 29!!
what the heck guys? i can fit my head between the wheel and fender!
help please....
Old May 23, 2008 | 06:43 PM
jminton's Avatar
Car: 1985 IROC
Refer to the picture in this thread : https://www.thirdgen.org/forums/susp...ion-101-a.html
Notice the two holes in the A-Arm that are closest together. The bottom end of your spring should be between those two holes.
Old May 23, 2008 | 09:06 PM
Car: 85 camaro
Axle/Gears: 342
yea i put the end of the spring right where its supposed to be....
Old May 24, 2008 | 01:41 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
how did u install them?did u unbolt both lower a arm bolts, install the spring and then bolt it all up. or did u leave the a arm bolts attached and just pivot the a arm down enough so u could slide the spring in? i did it the second way and had a bitch of a time trying to make sure it was lined up in the upper spring perch. it would all go back together normally but the wheel gap was huge. make sure the upper part of the spring is seated properly. and the end of the coil on the a arm HAS to be between those 2 holesthat are less than an inch apart (finger pointing to them in pic) otherwise it will be sitting too high. when i did mine the first time i had like 5 inches of wheel gap and the coil only had to be rotaed less than 1/2 an inch to correct the ride hight. if infact u have installed them correctly, then either thats how it should be or they are the wrong springs. stuff does get boxed wrong from time to time.
Last edited by 83Firebird420; May 24, 2008 at 01:49 PM. Reason: Automerged Doublepost
Old May 24, 2008 | 02:04 PM
Stephen's Avatar
Car: 87 GTA
Have you even DRIVEN the car yet?
Shocks can "set" higher, until compressed by simple driving and settle....
The rubber/poly mounts could be "twisted" into helping to hold the car up...
Since the arms pivots inwards when the car is jacked up, when you put the car back dow, the tires are effectively closer together, inwards, and the mere friction grip of the tires on the floor can be ANOTHER thing keeping the car from settling.
Take a leisurely drive around the block, measure it again, then come back & tell us what you have.
Old May 28, 2008 | 02:53 PM
Car: 85 camaro
Axle/Gears: 342
well you guys were right, the passenger spring was about 180* out of whack... i made both sides right and moved it around a lil bit and now i sit right at about 27 inches ground to the wheel wheel, is that about right?
Old May 28, 2008 | 07:24 PM
yeah sounds about right...post some pics lets see the car!
Old May 29, 2008 | 09:01 PM
StonersTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
Hey thanks for all your help with this guy because it shed some light on my problem too. I too had a front end that i couldnt figure out why it sat so high. I bough the lowering kit and the same shocks he did kyb gr2's and the back dropped and the front actually looks raised up. im going to use what i read on here and hopefully that will solve that problem. thanks alot everyone!
Old May 29, 2008 | 09:52 PM
im just relaying the info i learned from this site as well. without thirdgen.org ide still be driving around with the front end all raised up, wondering wtf.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Veaceonee
Sep 29, 2016 08:15 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
