Squealing while turning
Old Oct 27, 2008 | 04:18 PM
jbates346's Avatar
So whenever i turn either direction. theres a squeal i think coming from the front. I'm thinking it should be in the steering, however it kinda sounds like a wheel bearing. Has anybody else had a similar problem? I can't get to it until this weekend. Any tips or hints on where to start? Thanks for any help.
Old Oct 27, 2008 | 04:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Squealing while turning
Welcome to TGO. Start the car and turn the steering wheel lock to lock. If there's a squeal, check the power steering pump (when's the last time the fluid level was peeked at?).
JamesC
Old Oct 27, 2008 | 05:36 PM
jbates346's Avatar
Thanks for welcome. I've been loving IROC-Z's for quite awhile and i finally found one with the equipment that i wanted. Anyway i don't think its the pump. It's a higher pitch. I'll definately try it tho. It's more of a high pitch squeal, like a wheel bearing. There's also some noises when i brake hard that the suspension compresses. I just got the car last tuesday so i'm still figuring out all i have to do. I'm going to try and put it on a lift saturday, but until then i wanna figure out where to look. Thanks for idea......anymore?
Old Oct 27, 2008 | 10:31 PM
jbates346's Avatar
Ok I just did what you said and while sitting at idle i turned the wheel both ways lock to lock and heard nothing. It only happens about 10mph+. Do you think this could be the early signs of a wheel bearing going out.
Old Oct 27, 2008 | 11:42 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Check your front brake pads. If they're getting low the "squeelers" that warn you when your brakes are worn down can make a little contact with the rotors when you turn.
Old Oct 28, 2008 | 07:31 AM
jbates346's Avatar
Really front brake pads, but they don't squeak when i apply the brakes tho? I dunno i guess i'll check that out too.
Old Oct 28, 2008 | 07:59 AM
JamesC's Avatar
Jack the car up. Grab the wheel(s) at the 10 and 4 position and try to wiggle the wheel/tire. If there's movement, the wheel bearing is probably the culprit.
JamesC
Old Nov 5, 2008 | 04:00 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
my car has this problem to, i have a new front end pretty much and have done a few 4 wheel alignments and nothing has fixed it :/
Old Nov 5, 2008 | 09:10 PM
jbates346's Avatar
When its funny you guys said about the brakes. Today it started squealing/sqeaking when i apply the brakes. So ya its gonna get new brakes and rotors in the front. I'll try that and let you guys know. Doesn't look like i'll get to it til next week tho.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
