bmr lca width vs stock?
Old Jul 4, 2009 | 08:43 AM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
I got my c6 wheels on the bird but when i take sharp turns the rear tires rub on the control arms. My car is about lowered1.5''-2'' abd im waiting on my adjustable panhard to come in the mail. Also i dont have lcarb yet but they are coming soon. So are there any aftermarket control arms that are smaller/skinnier that will allow a little more clearence? Also for some reason the passenger side rear has always sat about an inch higher than the driver side????? Ive had the lowering springs in over a year and have messed with them a few times but could never get it fixed. thanks in advance guys!!!
Old Jul 4, 2009 | 10:41 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: bmr lca width vs stock?
most aftermarket rear lower control arms are smaller in diameter than stock, BMR's website will tell you what they are made out of. depending on style, they range from 1.25": wide to 1.625 wide. Both a bit narrower than stock.
Are you rubbing on both arms of just one? it probably has a lot to do with the lack of an adjustable panhard than just the control arms.
as for the rear height, are the spring insulators both in place and are both the springs indexed properly? the open end of the spring should be to the rear of the axle mount pad.
Old Jul 4, 2009 | 06:09 PM
Car: 1988 Firebird
Yeah im pretty sure its rubbing on both sides. Another thing when i take the turn my car does lean because i have small sway bars. I think once i get bigger sway bars it wont hit but theres only one way to find out haha
Old Jul 4, 2009 | 07:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
are you sure you are running on the lca?
what you need to do before you start throwing money at parts, is pull both wheels off and see if
1. both are rubbing
2. where they really are rubbing.
then you can intelligently pick a solution.
I just cant imagine that you are rubbing on both LCA's. Its most likely only one side rubbing because of an off-center rear.
Old Jul 4, 2009 | 07:39 PM
Stephen's Avatar
Car: 87 GTA
Bad bushings on the PHB, would allow the rear end to **** left & right & rub both wheels.
But ....Have you identified FOR SURE where the rubbing is?
A sway bar doesn't nothing to limit left/right travel & prevent rubbing. Only way the sway bar could affect the rubbing, is of the tires are rubbing the inner fender well, when the body leans in turns.
Old Jul 4, 2009 | 07:59 PM
Car: 1988 Firebird
Well I know for sure its rubbing on one side cause there is rubber dust on the driver lca but I do need to checkk the other Side. But It is rubbing somewhere on both sides
Old Jul 4, 2009 | 08:13 PM
Stephen's Avatar
Car: 87 GTA
My UMI LCA........2 5/8" vs 1 1/8"
Yeah....Tubulars will give you a good bit of room. If you need even more, get the offset bushing spacers, if you get rod-ended LCAs.
Old Jul 4, 2009 | 08:26 PM
Car: 1988 Firebird
Awesome Stephen, thanks for that picture! If after the panhard i still have problems those will deffinitely give me a lot of room
Old Jul 4, 2009 | 11:22 PM
Stephen's Avatar
Car: 87 GTA
Equal On-Car adjustables.....
BMR.....1.25" x .095" 4130 chrome moly tubing.
UMI......1.250" x 0.095" 4130 Chrome Moly steel
So if you get the adjustables too, the BMR ones will be the same as my UMI ones.
Old Jul 5, 2009 | 02:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
so im curious, what wheel are you using? backspacing and spacer? I've seen people here with 17x11's with stock control arms, only a little rubbing.
Old Jul 5, 2009 | 04:12 PM
UMI Performance's Avatar
Hello,
Thanks for the interest in UMI
You may also want to consider these- http://www.umiperformance.com/catalo...roducts_id=107
They offset the control arm inward an additional 3/8"... should do the trick for you as well
Also as noted a panhard bar to make sure the rear end is good and center is a good idea. Also if the factory bar or bushings allows the stock panhard bar to flex at all that will cause your issues as well. I would highly a panhard bar, we have a full list seen here- and we have 15% off right now! - http://www.umiperformance.com/catalo...Path=7_138_106
Thank you!
Ryan
Old Jul 5, 2009 | 05:48 PM
Car: 1988 Firebird
Well I think the rears are 19 by 10.5. And I'm running 295/30 still waiting on the panhard I'm getting from a member from here maybe he will include new bushings
Genopsyde
Oct 7, 2015 08:35 PM
lt1z350
Aug 28, 2015 05:57 AM
TheExaminer
Aug 25, 2015 07:34 PM
NBrehm
Aug 5, 2015 07:57 PM
