will a 4th gen driveshaft work in a 3rd gen?
Old Nov 24, 2000 | 11:35 AM
84IROC's Avatar
I want to up-grade to an aluminum peice and want to cover all options as far as what I can find second hand. Thanks
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front
23mm sta. bar in rear
rear lowered 1" by cutting 1 1/4 coils of '84Z28 springs
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Nov 26, 2000 | 09:44 AM
blowen90ta's Avatar
yes
Old Nov 26, 2000 | 10:54 AM
Jason M 91Z's Avatar
As blowen said, the 4th gen aluminum driveshaft will fit. Just to elaborate a bit, the 3rd gen aluminum JG1 shaft has a part number 10085375. I just ordered one from GMPartsDirect.com complete with yoke and u-joints for $242.14 shipped. Good luck finding one, and JamesC who's around here quite often sells the shafts for around $150 I believe. Check with him to see if he has any.
-Jason M. 1991 Camaro Z28
"Shampoo is better, I go on first and clean the hair."
Old Nov 30, 2000 | 11:31 PM
RARE-ROC-Z's Avatar
SO A FOURTH GEN CAMARO AUTOMATIC DRIVESHAFT WILL FIT A THIRDGEN CAMARO AUTOMATIC DRIVESHAFT THE SAME.. IF SO I HAVE ONE IN THE NEAREST JUNKYARD. OUT OF A 98 Z28. I WILL GO AND BUY IT TOMORROW.. THANKS..
1990 IROC-Z L98 350 TPI
AFPR 49PSI, GUTTED AIR BOXES, K&N, RAM AIR, PORTED PLENUM, B&M SHIFTER, 3.23 LIMITED SLIP, DUAL CATS, STOCK SUPER TURBO EXHAUST, COOPER COBRA XST's
MUSTANGS...ONLY 4 LUGS....HAHA THAT IS HILARIOUS.
Old Nov 30, 2000 | 11:40 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The LS1 driveshafts are slightly different, but I am told they will still work.
You're lucky to have a yard near you with late model stuff!! Around here, everything is 87 or older.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 1, 2000 | 10:34 PM
84IROC's Avatar
I WAN IT!!!!!!!!!!!WAHHHHHHH
Old Dec 9, 2000 | 05:46 PM
Blown GTA's Avatar
I have an aluminum driveshaft I bought off a guy who replaced his 2000 LS-1 Trans-am with a carbon-fiber one. Its virtually new only has less than 1,000mi. I pay $180 and I just want my money back.
87 GTA at the heart of the muscle lies a 350 with that big PITA Box induction, A used Paxton Blower that better work and a laptop to mess-around with the fuel and spark controls. The great ZZ-4 heads which are still virgins and a flat not roller bumpstick that Crane calls a single pattern for both 222*dur. &.450"lift at .050. Undestructible tranny I hope built by Dana and an expensive assed converter to fly off the hole. A F-word rear from Currie with mister spohns suspension. A ran up credit card bill and hopefully a fast as* car.
Old Dec 10, 2000 | 01:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Thanks for the plug, Jason. I currently have two of the 1LE type alum shafts. Both have unrusted slips but are missing the rear U-joint caps (I'd replace anyway). The JG1 will fit both autos and manuals, third and fourthgen through '97, I believe.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
dhonda200
Aug 11, 2015 11:50 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
