Third Gen Front LCA Bushings
Old Apr 29, 2010 | 06:01 PM
tiek101's Avatar
Does anyone know where I can find spherical bushing for the front LCAs for a Third Gen? We have an SCCA A-Sedan car that is equiped with them (came with the car) so I know they were available at one time. We are building another car and would like to run the same type bushings.
Thank you in advance for any information. -Keith
For information, they are very similar to these found at Speedway Motors:
Old Apr 29, 2010 | 06:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Third Gen Front LCA Bushings
not sure with the bearing ones, but global west makes delrin bushings for the a-arms. they also offer no deflection
http://www.globalwest.net/1982-02_Ca...m_bushings.htm
Old Apr 29, 2010 | 06:57 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
http://www.howeracing.com/c-483-prec...-bushings.aspx
Old Apr 29, 2010 | 07:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
VSE (Herb Adams) used to make them. Not sure if you could find any NOS sets. Wouldn't be too difficult to make them or have them made.
RBob.
Old Apr 30, 2010 | 01:14 PM
tiek101's Avatar
Thanks for the replies. I did previously find the Global Del-a-lum bushings and decided that's probably the way to go, but I figured I would ask anyway. ...I might try making them from Howe or Speedway stuff.
Thanks again.
Old Apr 30, 2010 | 04:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks again.
I would go with spherical bearings way before going with a del-a-lum (DAL). Too much play in the DAL setups, and, there is nothing in the design of the a-arms and K-member that specifies that the two mounts are exactly inline with each other.
I've posted a basic drawing of how to build a spherical bearing set up here on TGO.
RBob.
Old Apr 30, 2010 | 04:22 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
I've only got poly bushings right now drilled for grease zerks so I haven't had a chance to play with the del-a-lums, but where's the slop? From a maintenance standpoint I'd rather run the del-a-lums if I ever get around to replacing the poly stuff.
Old Apr 30, 2010 | 06:53 PM
tiek101's Avatar
Do you have a link to the drawing? I have searched and can't seem to find anything.
Old May 1, 2010 | 11:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Found it. Actually a decent thread with other good information in it:
https://www.thirdgen.org/forums/susp...-bearings.html
RBob.
Old May 1, 2010 | 04:42 PM
tiek101's Avatar
Thanks RBob! I think I'll give it a go at making a set.
Old May 4, 2010 | 06:35 AM
tiek101's Avatar
For anyone that is interested, I found what I was looking for. UB Machine Part number 32-0325 http://www.ubmachine.com
Old May 5, 2010 | 04:41 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
I guess I forgot to mention that they make them to fit 3rd gens too. I think the ones for the 2nd gen A arms work on our cars.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
NBrehm
Aug 5, 2015 07:57 PM
