Question about ebrake lever of older camaros...
Old Jun 21, 2001 | 01:42 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Ok from what I understand teh IROC's or the camaros of like 85-90 had a little adjusting thing on the cable. Or something like that. Ok does only the IROCs have this? or is it the 90- Camaros have that? Thanks
Chris
91 RS 305 TBI
Eternal Rev
Old Jun 21, 2001 | 12:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I thought they all (82-92) had that... no? AFAIK there's two adjustments; the adjustment of the rear brakes, and the adjustment of the handle.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 21, 2001 | 02:47 PM
92Camaro305TBI's Avatar
What does the adjustment do.. ???
92 Camaro 305 TBI Automatic. 2.5 high flow cat and 2.5 pipes into3.5in tip, shift kit. Tinted windows(legal)...
Future mods. Spark plug wires and plugs, Headers, O.E., any other advise on getting to 300+ HP would be appreciated. Thanks
System = Sony explode CD/MD receiver, Rockford 6x9 Fanatics, 4x6 Clarion in the front, 2 12" Hx2's(Rockford) in custom box(black carpet) 1 farad cap, 800x2= 932 total watts Rockford Amp 4gauge wire kit.
Old Jun 21, 2001 | 02:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The adjustment of the rear brakes is just making sure the clearance between the shoe/pad and drum/rotor is correct.
The adjustment for the e-brake handle makes the parking brake apply earlier. I guess you could go in reverse, too, and make the brake apply later. Basically it's how high the e-brake handle raises before the brakes work.
It's smack under the middle of the car. The "center parking brake cable" connects to the center of an "adjuster", which has the "left parking brake cable" and "right parking brake cable" attached. Use two wrenches on the center cable; one to move the nut, and one to keep the center cable from twisting. FYI, that center nut will be hard to turn after all these years.
Old Jun 21, 2001 | 03:01 PM
Ok is it unsafe to drive at 15mph and see hoow long it takes before it stops the cars... or do you have to be going faster.. I know I tried it, well it didnt stop my car/... So i didn't know if it was working right or not. IN OTHER WORDS.. how do you test your ebrake with out messing it up.?
Old Jun 21, 2001 | 03:27 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There is no threaded center rod to adjust on 90-92 F-bodies. The e-brakes are adjusted only at the calipers or the drums. If you swap in an earlier style disc brake rear end (as I did) you have to also swap the entire parking brake lever assembly as well.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Jun 21, 2001 | 05:22 PM
REVLIMIT's Avatar
Engine: Built L98
Ok thanks everyone...but heres teh question. Does the adjustible ebrake lever come on all older 3rdgens? or is it only the IROC's? Thanks.
Chris
91 RS 305 TBI
Eternal Rev
Old Jun 21, 2001 | 09:26 PM
Jza's Avatar
Jza
it's not an ebrake and is not meant to stop the car. it's just a parking brake and is to prevent it from rolling around, even if the car's in park for autos
BRoss99
Aug 10, 2025 05:08 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
